Old 08-08-2011, 12:06 AM
Drivers side door panel (inside)
More specifically the part that operates all four windows in the car. I guess I would have to get the whole inside panel. Mine has broken thru.
Mike
95 Pearl Blue L
Old 08-08-2011, 12:11 AM
Re: Drivers side door panel (inside)
I see an "L" model in your signature, so you are looking for the Grey piece that "holds" the window switch? that in the other models is a woodgrain, correct?
Old 08-08-2011, 12:13 AM
The master window switches or the trim piece they sit inside too? Every part is separate. If the switches have fallen down, the tabs that are screwed to the trim piece probably broke. You can most likely fix it with some epoxy or super glue, at least temporarily.
Old 08-08-2011, 12:26 AM
Thanks for the quick replies. Yes it is grey. The whole window control module just falls through and they're is nothing to hold it up anymore. I have used duct tape before but in this heat the glue doesn't hold up very good. I have a new window motor coming in any day. If I could get that gray piece maybe I can make some sort of bracket to hold up the control module. I have that gray piece but pieces that separate the four holes have broken off. Also the main drivers side switch has broken off. I use it but it won't stay attached anymore.
Mike
95 Pearl Blue L
Old 08-08-2011, 12:31 AM
Not just any glue, man.
Old 08-08-2011, 12:36 AM
I agree. If you don't want to go that route, and actually replace it, I have the parts, but am extremely busy. If someone else gets you the parts should you decide to replace them, I'd be interested in buying your current window switch assembly for a few bucks to see if I can make use of it if the buttons still work as they should and just the mounting tabs are broken.
