Old 11-18-2011, 07:24 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Look for a switch guys
I would LOVE it if somebody had the power mode switch that the japanese SVXi had, but that's not practical. So, does anyone have a shift-lock switch they'd give/sell to me? i'm just gonna put that where the power mode switch would go.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-18-2011, 10:55 PM
Re: Look for a switch guys
I'll check and see next time I'm looking through stuff.
Old 11-19-2011, 12:08 PM
Old Fogey
Just looking at the switch gear on mine, with a JDM Power switch, and you should be aware that: the power switch is a locking switch (also lit at night) while the shift lock button is not, and: the lock switch also acts as a mechanical lever to unlock the safety mechanism in the shifter, not as the electrical on/off locking switch that you want. Keep feelers out for the correct switch from JDM market.
Glenn
Old 11-19-2011, 12:27 PM
B 4 You's Avatar
#lolsvx
Glenn
no, i understand. what i would do is take someone's unwanted shift-lock switch (say, they converted to a manual) and trim it down a little and mount it to a push button switch. i know it wouldn't light up (easily ) but it would look nice and stock.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 11-19-2011, 01:32 PM
This is a possibility.
Back in 2003, Mike Novosel "nubs" did a similar setup, using the shift lock button and a micro-switch, to operate his garage door opener. Should not be that difficult to make it work with a PWR switch.
Of course there are other options. This switch operates my secondary alarm indicators and my LED grille light. Easy access with my thumb. Looks factory.
Old 11-19-2011, 01:35 PM
Personally, I would do the simplest solution, based upon the high-beam switches mounted on the floor of the older '50 and '60 cars.
Whenever you need the PWR mode, just depress it with your left foot to activate, press again to return to normal. An LED indicator could be wired it to light when it's engaged.
No holes to drill or modifications. Easy wiring from the TCU. Completely invisible and removable.
Old 11-19-2011, 04:42 PM
B 4 You's Avatar
#lolsvx
that is EXACTLY what i want. i am going to put a switch somewhere else for the mean time, but that is my goal. not surprised that you found the exact thing i wanted you're pretty much an svx dictionary, john.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 11-19-2011, 08:23 PM
The German SVXs have two switches for this purpose. Electrical so almost plug and play.
On for the Manual control and one for the power antenna.
In fact, the button of the side of the gear selector lets you choose between ECON (normal) and POWER.
Maybe some of our European members can get a part number...
