Old 04-27-2020, 01:19 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
Modded headlights wiring
Looking for wiring suggestions.
My headlights are modded with halos and I originally wired them to come on with the projectors. I have to get in there to change out ballasts and am considering re-wiring them as DRLs.
I can test various wires to find a hot one with ignition key turned on(engine not necessarily running)- anyone already familiar with the wiring under the hood have a specific wire suggestion? I'd like it to be clean-looking.
Old 07-10-2020, 01:11 PM
svxash's Avatar
svxash svxash is offline
Re: Modded headlights wiring
Any luck? I've been wanting to do the same.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 07-11-2020, 12:23 PM
WYOSVX's Avatar
Yes and no. I tested wires under the fuse box in engine bay, found one that was powered at ignition, then decided I didn't want to splice into it. I really wanted a factory look to where I'd have a switch by the wiper switch under the dash that'd turn on both tail lights and halos and have its own fuse.
Any possibility I could find was going to be a ton of work and wasn't going to make my car faster and the bling value of the having the halos as DRLs that way wasn't worth the trouble. So, I took the easy way out and wired them to the parking lights. Wires went through the rubber fitting behind the battery and did the splicing behind the corner light (easy enough to pull.) Only had to wire to that one, it provided plenty of power to the two Morimoto ballasts.
Now, for DRLs, my tail lights and front corners are on along with my halos. I like that the SVX has the dimmer over ride button at the tip of the light switch. That helps. I think clear corners would be even nicer.
I had the halos put in back in about 2012 before I noticed they really exploded in popularity. Were I to do something like that today, with there being so many halos, I think I'd go with something different. Still, it looks good enough and cost enough that I wanted to be able to see them. They fit the look of the SVX to me.
I keep forgetting that you are in Casper; one of the few other SVXs in Wyoming probably. It's a nice car to drive on our long open roads here! And the crosswinds are almost unnoticeable compared to driving my pickup.
Old 07-12-2020, 10:02 AM
SVX_MY_BABY's Avatar
FWIW here in Canada the DRLs are simply the fog lights. They are always on until you turn on the headlights. No tail or running lights involved.
Peter
Old 07-19-2020, 06:16 PM
That's how my halos operate - I just re-routed the fog light wires to the CCFL transformers so whenever the car is running with the parking brake off the halos light up. They extinguish when the low beams are on but I can bring them back with the fog light button.
I don't know exactly what the system is that makes the DRL activate. If you can find a Canadian scrap yard car you might be able to salvage the parts behind it and retrofit into your car.
