Old 01-12-2009, 08:07 PM
svxash's Avatar
svxash svxash is offline
HID's and snow/fog driving?
For those of you that have HID's and have driven while it's snowing or in fog is it hard to see while it's snowing or in fog? Is there glare or reflection off of the falling snow?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 01-12-2009, 08:19 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: HID's and snow/fog driving?
It depends mainly on the temperature of the HID lights. HID's are more effective in normal driving conditions because of their high secondary reflectivity off of objects in front of them. However this is a bad thing when driving in snow because it reflects off of the snow itself which is blocking visibility. The lower temp ones can throw out a yellower light which is better since it does not reflect back as much visible light.
Old 01-12-2009, 08:23 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Mine were ok in the snow. I have the 6000k. I need to upgrade my fogs so I can cut through that stuff better.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-12-2009, 08:26 PM
svxash's Avatar
I'm thinking of installing 4500k HID's.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 01-12-2009, 08:35 PM
I think if I put in pure yellow hid fogs it will cut the glare down a good bit.
Seth
Past subies:
Other toys:
Old 01-12-2009, 08:56 PM
I also have 6000K HID's and have no problem in blizzards. Not any more than I did with regular halogens anyway. There may be a bit more reflection and the colour is more blue, but it's nothing I can't deal with.
Old 01-12-2009, 09:20 PM
siceclipse's Avatar
siceclipse siceclipse is offline
i have them and i like them a lot.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 01-12-2009, 10:36 PM
I have the 5000K HIDs in both my projector low beams AND my fog lights. I was wondering how they would be in bad weather, since they were not auto leveling and thought about being able to disable ONLY the headlight circuit at will
[COLOR="Red"]REASONING:[/COLOR]
I did not know how the new HID system would operate in snowy weather from a standpoint of reflected glare from the snow back into my eyes or those of oncoming traffic. Since I drive quite a bit slower during these times, my need to see very far down the road with the headlights is decreased.
Putting H-3 HIDs into the fog lights, I would be able to use them as auxiliary headlights to still shine on the road adequately and not bother other drivers. I would turn these on with only the parking lights, leaving the main headlights off. They should be bright enough to adequately see, while also being bright enough to be seen by oncoming traffic.
I did a test last winter when there was snow on the ground and light snow falling.
I parked my SVX on a straight, deserted road with only my low-beam headlights on and walked about 500 ft. from the car and looked back at my car. I also sat in my car and looked out at the road to see what kind of visibility I had.
I then repeated the same tests, by disconnecting my headlights and using ONLY my HID fog lights.
CONCLUSION: I had better visibility using only the fog lights than using the headlights.
Using only the fog lights, I had more useful illumination on the ground before me and a good distance and no glare from the falling snow. In fact, all I could see was the road ahead of me and hardly any falling snow. You tend to drive slower during snow, so I never out-drove the distance I was illuminating.
Looking back at the SVX from 500 feet away There was a lot more noticeable glare, (from both the scattering of the light pattern in the falling snow and from the reflection from the snow-covered road, when I used the headlights by themselves.
When I used ONLY the fog lights, I could still see them more clearly, but the glare was greatly reduced.
So when driving at night in bad winter weather, I use only my fogs. I can see more efficiently and be seen as well by oncoming drivers, without distracting glare to them, or me from reflected snowfall. They look like normal headlights from the front (only closer together) With the headlights disconnected, I also lose high-beam capabilities, which is something you do not need in this kind of weather anyway.
So I can see and be seen, without the threat of blinding glare. Once we get snow here this winter, I will take comparison photos to show you what I mean.
Old 01-12-2009, 10:47 PM
This is from another post I did concerning tests done on a very foggy day back in November, 2007. This was when I found out the fogs alone were the way to go in inclement weather.
It was a VERY foggy day here in Maryland and I did a lot of driving in the afternoon and into the evening.
I discovered there is a lot more reflected glare from the projector HIDs than the stock halogens. This doesn't limit my visibility during the day, but at night it is a little more difficult to see beyond the fog... just a little.
Time for a test. I went home and put strips of duct tape over my projector HIDs and just used the HID fog lights. WHAT A DIFFERENCE!
The beam pattern was low and very wide and allowed me to see under the fog further than I ever have. More determined than ever to do this mod.
On a side note, from the view of oncoming traffic, the foglight-only HIDs are brighter at a distance than PIAA low beams. My son took his pearlie (with the PIAA 9005s I used to use prior to the changeover) and I took the polo to a long deserted dead-end street.
We parked them side-by-side, he with his low beams on and me with just the fogs. We walked down the road and kept looking back to see how far we could go before the lights disappeared.
At the point where I could not see his headlights at all in the fog, the Polo's fog lights were still very visible. The car seemed farther away than it actually was because of the fog lights being closer together.
Old 01-13-2009, 01:40 AM
subbieatnz's Avatar
i was shown some after market kits for HID lights 2day. i was very impressed. even got told they draw very lil amps.
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 01-13-2009, 10:20 AM
AFBeefcake's Avatar
Subaru Swapper
I have PIAA ION H-3 bulbs in my fog lights. It does help alot in snow/fog running the fogs with my HID lows.
2005 Legacy GT
My WRX's Cardomain Page
Old 01-13-2009, 10:50 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I have 8000k HID's and the stock fog lights and both work very well together.. What it really comes down to is, how old are you? Can you still see without using bi-focals???
Old 01-13-2009, 01:51 PM
Zandar's Avatar
Zandar Zandar is offline
Looks and smells great.
I have 4500k lows and 3000k fogs; no complaints so far. Way better than stock; I just wish I had an easy way to turn on the fogs only to see if it's better in the snow.
1992 LSL Pearlie: 108k, 15min/$15 mod, Alternator wiring "upgrade," Power Mode switch, K&N drop-in, 4500k 35w low-beam HIDs, 3000k 35w fog HIDs, lots more planned (pending funds, of course)- 4.44 5spd being at the top of the list.
"We laugh at honour and are shocked to find traitors in our midst."
-C.S. Lewis
Old 01-13-2009, 05:55 PM
siceclipse's Avatar
Zander, you got any pics of the fog lights?
did you keep the "sheild" in the fog light? or did you take it out?
Mike
Old 01-13-2009, 06:51 PM
JaySVX's Avatar
JaySVX JaySVX is offline
I'll be sure to let you know AS SOON AS WE GET SOME DAMNED SNOW!!! And I get some HIDs...
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
