Old 03-09-2014, 10:20 PM
Tapani Tapani is offline
Quarter panel rust repairs
The work has started !
Dismantled the mudguards, side garnishes and the rear bumper.
The cancer has been caused by missing "arch protectors" and torn mudguard. There was quite a bit of dirt on the wrong side of the plastic inner liner (mudguard in Subie terms).
The visible damage is actually easier to repair than the inner section....
So, the inner panel has rotted first, outside in, then when that has "gone thru" the outer panel has started to rot (from behind). The rearmost corner next to the bumper is naturally different - it's a single panel.
Anyone with "bubbles" in these areas - take the mudguards out and inspect before it's "too late".
/T
Old 03-10-2014, 02:41 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Quarter panel rust repairs
Man I am sooooo glad we do not put salt on the roads here in NZ (in fact I have only been in snow once in 40 years here).
Old 03-10-2014, 05:11 AM
Looks pretty similar to my car, maybe a little better. Good luck, can't wait to see the progress!
Old 03-10-2014, 06:25 AM
Will you be replacing the mudguards and arch protectors? I'll be doing the same repair soon. Could you post a few more close ups of the inner panel rot? I want to show them to my body guy.
Old 03-10-2014, 08:31 AM
Yes, I will replace the mudguard(s) - if the shipping cost is not astronomical.... it is a large but light part.... the arch protectors for sure.
I tried to get decent photos from the inside......
Good excuse to order more tools.... a sandbag and a mallet, a Cleko set, Intergrips and a shriker / stretcher .
/T
Old 03-10-2014, 08:52 AM
SVX_MY_BABY's Avatar
SVX_MY_BABY SVX_MY_BABY is online now
I tried to order front fender liners from Subaru. Was told no longer available.
Peter
Old 03-10-2014, 09:10 AM
Check this out:
http://www.monocoque-metalworks.com/...ar-wheel-arch/
/T
