Old 11-18-2010, 10:43 PM
torxxx torxxx is offline
4.44 swap completed!
Well, I've been putting it off for 5 months now, but its finally done. The deciding factor on finally doing it: my lifted 86 GL wagon with 550k+ miles on it, second transmission broke 2nd gear off the gear set and its damn near impossible to drive on ice to dry pavement with a welded rear end, having to jump from 1st to 3rd gear.
Took me about 10 hours of actual labor to get it done. I love how much easier the SVX is to work on compared to a legacy automatic. The SVX crossmember is a godsend, it actually makes it easier to drop out the transmission because it doesnt have that huge lip that overhangs the r&p like the legos and foresters have. So long story short, 98 Forester 4.44 trans and rear diff is what got installed today. I was going to put a 4.11 in until board members mentioned that they were pos trans and that the 4.44 trans has an extra set of clutches on the high side pump. Anyhow, I ended up using the 4.44 torq converter (the stock 3.54 converter was full of metal shavings, I couldnt think of a way to get all the metal shavings out of there) used the 4.44 flex plate because it was almost twice as thick as the stock SVX flex plate. SVX TCU and pressure control Sol.
My only real mind bender is the speedo sending unit. I put the SVX on in since it was a 3 wire and the 4.44 was a 2 wire. What or where do I need to go to get ahold of a 4.44 speedo sender thats a 3 wire? or what do I need to do to get my speedo back to semi accurate?
Is there anything else that I need to know about or need to worry about with the 4.44? it sure does get up and go and bang gears a hell of a lot faster than the 3.54. Thinkin about getting a clutch type LSD for the rear too since the car has 179k miles on it and the VLSD is most likely worn out. What swaps are you guys doing for reg. LSD rears? or torsen gleason rear diff?
Thanks guys appreciate the input and what not and getting me to go with the 4.44. Time to go get the custom 4.44 Alaska license plates ordered now
Old 11-19-2010, 12:40 AM
NeedForSpeed NeedForSpeed is offline
Re: 4.44 swap completed!
Your speedo will be accurate, you don't need to do anything more.
If you want to swap STI rear parts, you can build a R-180 4,444 rear diff with a clutch type or torsen center from the appropriate STI. The hard part is finding a 4.444 diff, that's JDM only. Also, you need STI axles.
Nice job
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 11-19-2010, 02:16 AM
ugg just went and picked my wife up from work at midnight and my multifunction switch (headlight switch/turn signal switch) has a short in it. Time to find a decent used on on here.. Anyone have an extra one they will sell ? I got $ on paypal ready to go
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 11-19-2010, 08:33 AM
you need the switch off the steering column? I have a complete steering column so I just need to disassemble everything to get to it.
How do you like the 4.44's?
Old 11-19-2010, 09:28 AM
What is happening with the switch?
Old 11-19-2010, 11:00 AM
yeah its the switch on the steering column. runs the headlights, turn signals wipers etc.
the 4.44 is amazing! I shoulda did that the day I got the car. Considering I got the car for free, the 4.44 swap was free, bridgestone all seasons for free. I have around $450 into this car and its the sweetest driving car I've ever driven. I'm really kicking myself in the ass for not aqiureing all the SVX's in my town. There is 3 other ones driving around. 2 92-95, 1 claret, one teal like mine and then a black 96 thats sooooooo beautiful. its got 18 inch konigs on it, definate car envy there. So yeah, I love the car now, just sucks that we only have 5 hours of daylight atm and I got no headlights lol
Old 11-19-2010, 08:41 AM
Nice job
The spedo will be 5.5% high.
Old 11-19-2010, 09:27 AM
He shouldn't pull it up so tight
