studs breaking off
i have 18 inch enkei rsv wheels on my svx with the rings and when I go to take off the wheels i always break studs. iIhave replaced all the studs thinking they were just old and ****ty but then i went to take the wheels off and a few studs broke again i only torqued them to like 80 ftlbs not even and the snapping off when i take them off. Im probly going to sell them this spring if i cant figure out wats going on cause I feel like i cant go out of town cause if i get a flat im f@#$ed so please help or throw out some i deas for me to try this spring!!
*1994 5 speed, Barcelona Red W/ Black ebony pearl top FWD*murrano wheels,lowered with motorsports springs drilled and slotted rotors 20% tint,swapped in leather seats,full exhaust cat delete,15 min mod, red F&R energy bushings |
Re: studs breaking off
you might like to check what torque wheel nuts are meant to be tightened to.
I've been cranking mine down to 75 for a good while, and if that was too much, my studs would be gone for sure - I changed my wheels more than 20 times last year.
"80 ftlbs not even"... Are you using a torque wrench? Please say that you're not using an impact gun!
How many turns of the nut does it take to install the nut fully onto the shaft with the wheel installed?
Our stock wheel nuts turn about 15.5 turns to fully seat against our stock wheels. Whats a life? Ideally you want 12mm of engagement for a 12mm diameter bolt/stud/nut. It takes 9.6 turns to have a nut fully engaged. If your wheel nuts take fewer turns it puts more stress on the engaged threads. Are you using a capped nut, or an open nut? An open nut will allow water and salt to enter easier than a capped nut. BTW, stock is 69-83 ft/lb.
Put anti seize on the threads when you replace the nuts. This makes it easier to remove.
Axle nuts, wheel nuts, pinch bolts, you kind of want them to stay tight.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 02-20-2009 at 09:13 PM. |
Are you tracking the car or driving it like you stole it all the time? Bigger rims put more stress on hub parts and in turn on the studs. If you're tracking the car, I would expect studs to break with such big rims. Especially if they're the wrong offset.
10 characters.
I do a lot of drifting just walking across the room
Apologies to OT... Let me start over.
svxAl: Is it safe to assume that you're not using the stock lug nuts?
im not using stock lugs have tried 3 sets of different ones (stocks wont fit)
10 characters.
Are you sure you're using the correct 12mmx1.25mm thread pitch lug nuts, as 12x1.5 is more common, many places will try to give you the 1.5 ones, which will cause similar results....
Keith |
