Exhaust
I am currently ordering all the parts for my dual exhaust set up. I have ordered 2 dyno max muffers high flow welded(which allow the most airflow thru); 2 BMW schitner exhaust tips and I need some info on a cat. I was looking on buying 2 Random cats. The sight and the company seems like they have a good rep. Has any heard or has these I want to know what they are about. They are $280 pricey a piece. Or help refer me to better converters. Also planned on running 3" pipe. Is this bad or good or go with 2 7/8"?
This is my first post. 97 Red SVX
Need more info about your exhaust to give advice. Dual pipes from the manifold back? Cat back?
yeah replacing the cats and dual the rest of the way back(no res)
If you are going with true duals, then 3" is WAY too big!
, unless you have other mods, like NOX, turbo, supercharger, stay with 2" id MAX for true duals, and 2.5" id max for a single. You will lose a lot of bottom end if you don't. Tom
-Chike
to be honest, Random Technology cats never sold
that well, the best cat for your $ is to buy Carrsound cats (dist thru Magnaflow too ) The LS1 club in Tx did dyno testing various cats last yr and Carrsound came out on top.
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
I agree that 3" is too big.
For the SVX I think 2 - 2.5" is the best for keeping the weight down, better clearance and for scavenging exhaust gases by maintaining an ideal exhaust flow velocity. BTW, has anyone tried the Moroso Spiral, Edelbrock Tru-flow and Hooker Header Aerochamber mufflers? |
Might sound a bit too extreme, but the more I read about exhaust systems, the more I convince myself that the primary pipes could be kept as small as 1.5" OD for best all-around performance. For dual exhaust, step up to 2.25" OD at around 35-55" from the exhaust manifold.
motorsport ty for the tip on the random cats that can save me alot of money on this project. I want max proformance but I want a truely aggressive sound. What if I went with a 3" inlet and a 3" outlet on the cats (to open the resticted flow more) to a 2 1/2 pipes back to the mufflers.(Dynomax ultra flow welded) Then 3"into mufflers and out to tips. Would that be ok to go from 3" to 2 1/2 to 3" and out? I figure the bigger the pipes the deeper the sound. Or use 3" to 2 3/4 to 3" or not. I know you all suggested smaller I just want to here alot of different opinions. 97 red in the beginning stages (off the record it has been -50 for 6 days strait.)
As I recall someone went to duals before and said it sounded whiney and ricey, basically turns it into t 1.65L engines so you might want to find out what the outcome has been from previous people.
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
Does Alaska have yearly emission inspections? You might want to consider just running a single high flow cat (I got a Magnaflow piece from Dayle's shop) around 60-70 inches back from the engine. Since I'm reading the same theoretical info as Mychailo ( ), I'd also recommend keeping the size of your primary pipes small in order to keep your engine's bottom end performance (see Tom's comment above). The Subaru engineers did a good job with the exhaust manifolds and you can basically look at the engine almost as two 3 cylinder engines. You might want to consider going with primary pipes of around 1.5 inches I.D. feeding into a Magnaflow high flow cat with 3 inch inlet and outlet (the cat would serve as your expansion chamber) and then running 3 inch pipe back to the tips you want.
-Bill
New Christmas book Mychailo? Todd
Down to none |
http://www.cafefoundation.org/aprs/EPG%20PART%20IV.pdf Seems to suggest that mass velocity is far more effective than sonic reflections at generating a vacuum at the exhaust valve in the latter part of the exhaust stroke. Unfortunately, the article doesn't go into enough depth to get sufficient info to accurately apply the concepts to the SVX.
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 01-16-2005 at 09:56 PM. |
Todd,
1. Smith & Morrison - Gods of Exhaust Design! 2. Aren't you supposed to be on vacation? Mychailo, Think we should start welding up an R&D exhaust with "blind legs"? Did you catch the "...single most effective way to increase the Subaru horsepower output..." comment in the article? I've got to read the article a couple more times - I'm still wrestling with the tuning for sea level and tuning for 8-12k feet of altitude info presented (as I really don't have any desire to yank the engine out of my car and put it into a plane ) -Bill (ready to weld up an R&D "chamber/muffler", just waiting for the signal....)
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 01-16-2005 at 11:51 PM. |
