Are the middle row switches backlight?
I meant backlit.
Now that I'm finally able to drive my SVX, I noticed last night that none of the middle row of switches (eg, the fog light switch) is visible in the dark if it's not turned on (yes, the car was running and the headlights on). Should they be? It's kinda hard to find them in the dark if not. Thanks,
Rod. '97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD '92 Ebony LS-L #6851, USDM (sold) '08 Forester (wife's) '06 STi (traded for the Forester) '94 Legacy wagon (sold) Last edited by Rod.; 10-03-2011 at 11:50 PM. |
Re: Are the middle row switches backlight?
Yes they should be lit when you turn on the headlights. The security, cruise, fog light, defroster, and I think the hazard light button too should all have backlights for the button labels. So should the buttons underneath them (parking lights/mirror heaters, heated seats? Since you're in Canada). I imagine the bulbs are kinda difficult to change. The buttons themselves are not that hard to remove though. I can walk you through that, done it a couple times.
Hopefully someone (SVXcess) will be along with the part numbers for those bulbs.
COMPLETE LIST OF SWITCHES THAT ILLUMINATE. Each switch has its own bulb. SPOT DOOR ROOM SPOT - wording on overhead console illuminated green CRUISE - wording illuminated green (amber LED when active) FOG - symbol illuminated green (amber LED when active) SECURITY - wording illuminated green, ( red LED flashing unless the security system is turned off or the ignition is turned on) REAR DEFROSTER - symbol illuminated green (amber LED when active) HAZARD - triangle illuminated red . (Does not flash when activated) HEATED OUTSIDE MIRROR - symbol illuminated green (amber LED when active) PARKING - symbol illuminated green (amber LED when active) There are no no amber LEDs on the 92. MIRROR CONTROL ARROWS- directional arrows on round button illuminated green AUTO POWER WINDOW - LED illuminated green on this switch The wording on the mirror control is NOT illuminated. The word AUTO on the power window switch is NOT illuminated The sunroof buttons are NOT illuminated (arrows are painted on) The bulb number for the illumination of the switches you mentioned is 83426PA020 In your case you need 3. The chart that shows the part numbers for the bulbs can be found in the How-To documents HERE Apply pressure to the rounded end cap on the left side of the assembly. Press inward and rotate out, I use a butter knife with a terry cloth towel (or similar) over it, to give me some leverage and prevent scratching, and pry it out. When you pull out the switch clusters from the dash, the illumination bulbs are inside the BROWN sockets They are the ones closest to the face of the switch panel. The BLUE sockets towards the rear house the indicator lights. I have never had to replace those. Using a small screwdriver, hey just twist out with a quarter-turn. Check for proper illumination before putting switches back into the dash. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-04-2011 at 06:15 AM. |
You can also go to Radio Shack and purchase:
#7219 Micro Lamps ( 272-1092C ) 12 Volts 60mA Wire Terminal Base They come 2 in packs.
These work very well, and are usually in stock. They're in plastic bags in the pull out drawer section near the back of the store. You need to reuse the plastic bases, and bulb condoms from the original lights.
Thanks much everyone for the quick and detailed replies and info!
Just for fun, I called Subaru with the part number for the bulbs. It's 3 days to get them and they're 'only' $4.73 each, so thanks lots for the info about Radio Shack.
Rod. '97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD '92 Ebony LS-L #6851, USDM (sold) '08 Forester (wife's) '06 STi (traded for the Forester) '94 Legacy wagon (sold) |
these are illuminated?! maybe it was tampered with since my sunroof isn't stock (those at the past reading saw) definitely looking into this this weekend.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
It's weird that every one of my switch lights are burned out.
What's different about your sunroof? Glass?
I got the 2 switch bars out under the instrument cluster without breaking anything.
And then the lower left one with the mirror defrost/parking light came out okay but does anyone know where the illumination bulbs are for that one? The switches I haven't been able to get out, though, are for the sunroof buttons and the 4 lights in that cluster. Any advice for those? Thanks again.
Rod. '97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD '92 Ebony LS-L #6851, USDM (sold) '08 Forester (wife's) '06 STi (traded for the Forester) '94 Legacy wagon (sold) Last edited by Rod.; 10-04-2011 at 09:53 PM. |
Sunroof buttons - remove the two covers/lenses for the map lights, and then there are a couple screws up there. Undo them and you should be able to take it from there.
The wording on the 4 buttons on the sunroof control are illuminated. The sunroof buttons arrows do not light
For the room light switch, carefully remove the two lenses over the spotlights with a small flat-blade screwdriver. They are slotted for this purpose. Once the lenses are out, you can see the 2 Phillips head mounting screws. Remove the two screws (one each side) that you now have access to. Pull down the assembly and disconnect the wiring harness. On top there are two sockets with a screwdriver slot, similar to the lights on the dash. These are the bulb holders. Each bulb illuminates 2 buttons. Unscrew the bulbs with a quarter turn. The replacement bulbs are 83426PA000. Reassemble and reinstall. Since they last a long time, I prefer the ease of using OEM bulbs, as opposed to using Radio Shack Micro Lamps .
OKAY!
Great info as always -- thanks again. Are the mirror control switches supposed to be illuminated?
Only the 4 directional arrows are illuminated. The lettering is not.
This is quite hard to disassemble to try to replace non-replaceable bulbs. OEM switches are still available. 83071PA020MD (Gray)...$56.82 83071PA020DO (Beige)...$62.93 .
Would you know, though, if the Mirror Defrost / Parking Light switch has bulbs that are replaceable? I got that switch out but couldn't see any bulbs. Cheers!
