#421
#422
I'm thinking of a stand alone switch and running power to the fog ballast through diodes.
#423
You know my regular driver is my small mazda, that thing has single bulb for low/hi beam. Since that's my daily drive, if I get a pair for that car...when I start driving my SVX more next time, I wonder can I move my ballasts to the SVX and get the different HID bulbs and put them with my SVX.
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
#424
If I were you, I would do LEDs tail lights/signal lights, all HID bulbs and even the HID reverse lights PS: John, it's really bright...hope to see that in person one day.
#425
That shouldn't be too hard. You live in a neighboring state and I go to WV frequently to visit Tom.
Plus there's always Reading!! and the name is not Mr. SVXcess. just svxcess (all small letters) Dr.Dremel, Ph.D. will do nicely also; the Ph.D. stands for Polishedhighly.Detailed .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-02-2007 at 07:29 AM. |
#426
One of the other questions that came to mind was concerning the diminished heat output of the HID bulbs.
My lenses were frosted over in WV last weekend. I turned on the HID low beams and my normal halogen hi beams as well. After a few minutes, the heat from the halogen hi-beams had melted the frost completely, while the area in front of the HIDs were still frosted over. I am wondering how these HIDs (low beams and fog) will function when driving in winter weather with ice, snow or freezing rain. Will the lenses be warm enough to keep the precipitation from freezing? Normally, they got hot enough to melt whatever touched them. I guess all other HID systems have the same problem. Might be spraying a lot of de-icer on the headlight shields this winter... .
#427
mr. svxcess, you can modify and install heated headlights washers to posssibly avoid the problem...
#428
#429
This I gotta see!
#430
A note on European SVXi and HID's
I got a PM from Rinus, the guy in the Netherlands, the other day, regarding the HID's we sent him. It turns out that they don't work in the European SVX's, more correctly, they don't fit. I didn't get to ask him exactly what the problem was, but anyone who has the European version, check to see what bulbs it has and/or how they go in and let us know so that we can figure out a workaround.
Fortunately, Rinus' mechanic has an American version and bought the lights from Rinus and installed them in his own car. Anyway, just a warning for anyone who is thinking about upgrading to the HID's and has a different build than we do here in the States -- check to make sure our 9006's will work in your car!
Diana 1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint |
#431
The European headlight assemblies do not use the 9005/9006 bulbs. They use the old halogen H3/H4 bulbs. See this diagram I received from one of my German friends when trying to get German glass headlights.
http://www.subaru-svx.net/forum/atta...0&d=1031173866 If I recall correctly, the low beam for the headlight assemblies has a bulb adapter held in place with three Phillips head screws for either a H4 or the 9006 so that could be quickly swapped. Worth checking out. .
#432
I hope you guys are careful with the HIDs installed as fog lamps or brights! having them in a projector housing is bad enough, (in my opinion a retrofitted projector housing with an arc discharge capsule is better than a factory reflector style HID setup) but the changing from a halogen with a transverse filament to an arc discharge capsule could really cause some serious glare to other drivers. I have also noticed in cars (other than the SVX) that a retrofitted reflector style light ends up with the same or worse distance light but dramatically increased light output out the sides of the light. Having HID low beams and fogs must be crazy bright, and has gotta be blinding! The fluting on the polycarbonate shield should also deflect some of the light, but i don't know if it is better or worse.
having said that, someone needs to figure out a way to make the signal lights on the front of the SVX into cornering lights with xenons in them
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
#433
Now I'm all ears if someone can make our reverse lights brighter
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
#434
I bought a set of 50 watt bulbs at WalMart for about $6.00 years ago. Hope that helps.
#435
I bought some 50 watt lights that work great too. I bought them some other place than WalMart. They work great.
