Old 03-01-2013, 04:40 PM
oab_au oab_au is offline
Re: Total shutdown with elect power suging and fried fusible link
Replace your alternator....
the regulator is internal and is what causes this. So there is no prevention.
We can't prevent the regulator from failing. , but we can prevent it from destroying a lot of electrical components in the process.
If you look in this thread, at post 15, it shows how to reconnect the alternator wiring to prevent this trouble. Post 27 explains why it happens.
http://www.subaru-svx.net/forum/showthread.php?t=49727
It is not a difficult job to do, but good insurance.
One Arm Bloke.
Tell it like it is!
Old 03-01-2013, 06:03 PM
So basically what you're saying is that I need to put another 100+ amp fuse on the alternator output? Here is what my wiring currently looks like: http://www.subaru-svx.net/forum/showthread.php?t=58723
Old 03-01-2013, 06:05 PM
Its the new alternator wiring modification in the How-To Documents HERE
The two wires that were shortened were originally joined together at the alternator post, all that had to be done was to remove them from the alternator post, shorten them and connect them together.
This restores the original circuitry and its inherent safety elements, but excludes the original alternator output, which now has its own dedicated, fused line to the battery.
Implementing this modification is easy, safe and removes and isolates the alternator output from the rest of the electrical system. As it seems that the voltage regulator within the alternator is the weak link and is most prone to go bad, most would want to guard against it. This does exactly that.
This modification had been in place on my 96 Polo since February, 2010 with zero problems.
Old 03-04-2013, 06:27 AM
macadamianut macadamianut is offline
ECU/TCU on the way. Will test and report back.
Thanks for the help.
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
Old 03-04-2013, 03:04 PM
Sounds good. If the pump doesn't run go for the relay.
One Arm Bloke.
Tell it like it is!
Old 03-04-2013, 04:22 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
A great diagnostic and how-to thread. I look forward to a successful closure.
Gene
Gene and Ben
Old 03-12-2013, 08:42 AM
Okay sad news,
ECU replaced and ignition fuse pops when key is switched the on position. Even before cranking. Fusible link stays good.
What next? Ground issue somewhere?
Mac
Old 03-12-2013, 12:47 PM
Okay sad news,
Is the ignition fuse connecting the starter and ignition switch? Is it worth looking into the switch?
Mac
Old 03-12-2013, 04:39 PM
As I said before, "Yes that looks likely. Fuse16 feeds the ECU, but also the fuel pump relay, that would have been closed when the surge happened.
So If the fuel pump won't run, even with another ECU have a look at that."
If you can find the pump relay, (don't know where it hides,) and unplug it to see if that is the problem.
One Arm Bloke.
Tell it like it is!
Old 03-13-2013, 03:49 PM
John, I think this needs its own thread. Macs problem has not been resolved yet.
One Arm Bloke.
Tell it like it is!
Old 03-15-2013, 01:24 PM
Harvey,
As per your previous suggestions:
1. Tried unhooking the fuel pump relay (both relays, not sure which is the fuel pump) under the dash attached to the steering column which still popped fuse 16 when ignition switched to ON position. So no joy there.
2. All fuses out of underhood box. Replaced one at a time until interior ignition fuse #16 popped.
It appears that SBF #4 slow blow fuse #4 is the circuit the fault is on. The SBF's themselves are not blown.
Also to mention that the car will crank even though fuse 16 is blown. All accessories still work. Wipers, climate, radio, windows, hazards, etc.
The quick connect to the alt voltage regulator has two wires that both look like they had gotten pretty hot.
Hope this info helps to narrow things down.
Thanks,
Mac
Old 03-16-2013, 06:23 PM
Harvey,
Thanks,
Mac I see in the Supplementary book for the 95, that the Fuse 16 also feeds the Air bag system. So if you can unplug the Air bag control unit, then see if the short has gone.
I don't know much about the wiring for the Air bag system, but it does warn to "disconnect the Neg battery terminal for 20 seconds before doing anything to the Air bag system.
One Arm Bloke.
Tell it like it is!
Old 03-16-2013, 11:34 PM
So that you do not keep using up fuses, connect a 12 volt bulb in place of the fuse. If with the ignition ON, there is a short circuit the bulb will light up. If you clear the short the lamp will go out. Do you have one of those cheap test lamps with probes?
Regarding fuse 16:
The ignition coils are supplied via fuse 16. Disconnect the grey colored 8 pin plug B4 from socket E3 which you will find on top of the engine towards the rear and connected to a lead running through the bulkhead. See if the short circuit remains.
Are there any aftermarket accessories which have been added to the car, and which only operate when the ignition is turned on? Is there any wiring left in place which could have been left over from an accessory which has been removed and which could be shorting?
In my past experience, when everything electrically was working as it should and then a problem or symptoms suddenly appears, think back to the last thing that you did before the problem occurred. I have undone a mod or two and the problem went away.
Old 03-18-2013, 02:38 PM
Okay, will check for errant accessory wires and try the B4 E3 disconnect.
What is on the slow blow fuse #4 circuit?
Will also try disconnecting all airbag related devices to see if it is in there. Disconnect both battery leads for 10 minutes first? I think I read that somewhere.
Thanks,
Mac
Old 03-18-2013, 05:25 PM
Thanks,
SB fuse 4 supplies all the ignition circuits.
So if you can tell if the short happens on which of the three positions;
When the key is turned to Acc
Or when turned to ignition ON.
Or when you turn the key for the starter to work.
We can look at those circuits.
One Arm Bloke.
Tell it like it is!
