Speed per gear
I guess the 5/6 speed guys will be answering this . What can you get out of each gear .. Looks like 40 something in 1st and 60 something in 2nd and 3rd is in the 100 range and I chicken out after that.
Re: Speed per gear
Your too OLD to be thinking speed Fastest I ever went in a car was 140mph in a mustang
1995 POLO LSI 76K MILES SOLD Last edited by SVX92-97; 10-23-2011 at 03:26 PM. Reason: edit |
Re: Speed per gear
Assuming 6500 rpm redline mine would be:
1st - 34 mph 2nd - 52 3rd - 70 4th - 92 5th - 117 6th - 147 Assuming 7500 redline: 1st - 39 mph 2nd - 60 3rd - 81 4th - 106 5th - 135 6th - 170 All theoretical, obviously. There is a good calculator for it here: http://www.f-body.org/gears/
Re: Speed per gear
Gear ratio/ RPM / Speed Calc:
http://ctny.audiworld.com/mark/s4/gears/gear_calc.html I plugged in some #'s: 2011 legacy 6 speed manual: 1- 3.454; 2- 1.947; 3- 1.296; 4- 0.972; 5- 0.825; 6- 0.695; final- 4.111 Estimated Speed at 6500RPM: 1st - 35mph, 2nd - 62mph, 3rd - 93mph, 4th - 124mph, 5th - 146mph, 6th- 174mph 4.44 (98 legacy outback): 1- 3.03; 2- 1.62; 3- 1.00; 4- 0.69; final- 4.44 Estimated Speed at 6500RPM: 1st - 37mph, 2nd - 70mph, 3rd - 112mph, 4th - 162mph |
Re: Speed per gear
so where would the 3:90 5 speed be 1/2 way between?
Re: Speed per gear
3.90 5speed (6500RPM):
1st - 3.545 2nd - 1.947 3rd - 1.366 4th - 0.972 5th - 0.780 final - 3.90 1st - 36mph 2nd - 65mph 3rd - 93mph 4th - 131mph 5th - 163mph |
