Old 08-25-2008, 08:35 AM
Mr. Bill's Avatar
Mr. Bill Mr. Bill is offline
Where the heck is Millington?
Tire Wear Photo - Need Advice
Front tires have both worn quickly on inside corners (cupped). One in photo above is down to cords in one place.
Wear is more severe in some places (not even all the way around)
Car is 1997 with 62K and driven very seldom and with great care. Tires are 225/40 ZR18 (92W) Toyo Proxes T1S mounted on ADR GT Sports, 18 x 7.5, 5x114.3 with offset of either 42 or 48 (info from ADR - these were on car when purchased.) I inflate fronts to 40 psi cold and rears to 36. Rears are wearing evenly.
I understand that cupping is usually associated with negative camber. Before I replace the fronts, I need some advice on what to do to correct the problem. Will an alignment take care of it? Anything wrong with tire/wheel size?
Anyone have similar issues?
Thanks for your help ...
1997 LSi, Brilliant Red, 62K, #204
1999 Outback Limited, Black, 182K
US Navy Retired (CWO3)
Old 08-25-2008, 09:14 AM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
Re: Tire Wear Photo - Need Advice
Allignment should do it, but you'll want to have your components checked also. The top of the wheel is tilted too far inboard.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 08-25-2008, 03:48 PM
TurnInConcepts TurnInConcepts is offline
Check the toe, but with it localized in such a small severe strip have them check the front control arm bushings to make sure they aren't dead.
Old 08-25-2008, 04:53 PM
Two guesses.
1. Defective tires. I've seen it before, we had a Saab come into the shop with all 4 tires worn like that. That batch of tires had been screwed up and the steel belts were too small, allowing excessive flex of the shoulder. We put the car on the alignement rack to check and everything was bang on spec.
2. Check to see if the tire is touching the lower spring perch (the strut). If that's the case you either have too much camber, or something is broken/bent.
You're running standard width wheels and tires, with less offset (the wheel is pushed farther out), so that can't be the culprit.
Old 08-25-2008, 05:42 PM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
Anytime I have had tires with tread like that they always dissolve in like one summer...damn HP tires are a waste of money
Old 08-25-2008, 06:19 PM
Three words for you: General Exclaim UHP. Well, two words and an acronym. 400 treadwear rating. I've had mine on for ~6000 miles and they look brand new, still have some of the little nubs left.
Old 08-25-2008, 09:00 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Originally Posted by Crazy_pilot View Post
Two guesses.
I worked at a tire shop and would have said thought the same 2 things.
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 08-26-2008, 02:32 PM
immortal_suby's Avatar
Thread Killah
Looks like the way every set of yokohamas I've had on an svx wore out. Always thought it was my suspension/alignment until I switched brands.
Locker Link
2015 BRZ Limited 6MT
Old 08-25-2008, 08:26 PM
major7venth's Avatar
major7venth major7venth is offline
M7
Looks to me like very low tire pressures.
