Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 12-27-2008, 10:31 PM
sicksubie's Avatar
Wilwood BBK kit coming soon
I have been working with a local brake supplier on getting a BBK together for the SVX. I am bringing my pearlie to get measured up this coming weekend. There will be a few options available. The kits will range from an "economy" 4 piston, 1 pc rotors, ss lines kit to a more extreme 6 piston kit. You will be able to pick and choose what way you want to go. A breakdown of prices will come later...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-28-2008, 12:27 PM
ShiuludeSVX's Avatar
Re: Wilwood BBK kit coming soon
Cool. Thanks for the legwork.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 12-28-2008, 10:00 PM
Will this be a front only kit, or are there any thoughts to a 4-wheel system?
Also, how much braking force can the master cylinder apply? Hopefully that's not going to be a limiting factor with massive calipers.
Old 12-29-2008, 06:42 AM
sicksubie's Avatar
I have only been talking about a front kit for right now. If the master cylinder proves to be a weak point that can be upgraded as well, but I do not think that it will be....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-22-2009, 10:45 AM
svxash's Avatar
svxash svxash is offline
Will this kit work with the stock wheels or will you need 17" or larger?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 01-22-2009, 10:51 AM
Sov13t's Avatar
Sov13t Sov13t is offline
and also... any updates on this?
Old 01-22-2009, 11:20 AM
sicksubie's Avatar
I am trying to work out a common time to get my car to the place where it will be getting measured. Considering I just had to ravage my pearlie for the alt, fusible link, crank angle sensor, and battery it might be a week or so.... Yes there will be an option to get a BBK to fit under 17" wheels. It will definitely be a 4 pot kit though....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-08-2009, 09:38 AM
sicksubie's Avatar
I brought my car yesterday to get measured and to get some different brake options mocked up. Here is what came out of it...
First option is a set of Wilwood 4 piston fronts with pads and stainless steel lines, paired up with a set of rotors...
Price breakdown:
Kit = $1,200.00
Kit with DBA 4000 series rotors = $1,400.00
Second option is a 4 piston Brembo caliper off a Cadillac CTS-V. These calipers do not need the additional mounting brackets as the mounts on the caliper itself are just modified. This is a VERY beefy caliper as it was made for a 4000lb car making 400hp. These would be ordered straight from GM Racing and then paired up again like option 1 with stainless steel lines, pads, and rotors...
Price Breakdown:
Kit = $1,400.00
Kit with DBA 4000 series rotors = $1,600.00
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-08-2009, 09:51 AM
sicksubie's Avatar
Either one of these set-ups will be the absolute maximum that you can fit under a 17" wheel BUT, there are possibly some 17"s that the CTS-V calipers will NOT fit under.... 6 piston set-ups are possible as well if someone so desires....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-09-2009, 08:04 AM
Sov13t's Avatar
Great stuff,
With little research, it is my understanding that the CTS-V used the 4 piston Brembo calipers in the rear, and in the front they used the 6 piston Brembo's... is that correct?
Is it possible to obtain DBA 4000XS?
Also, what about the rears?
Old 02-09-2009, 08:53 AM
sicksubie's Avatar
This is it... The 2009's are coming with 2 different versions of a 6 piston set up...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-09-2009, 08:55 AM
sicksubie's Avatar
I can get rears done, but unless you are wanting to just spend money then you really should not worry about them for a while. DBA 4000's are available as well as 2 piece rotors. The 2 piece rotors add to the price though...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-09-2009, 10:16 AM
I want something like this on my SVX:
http://my350z.com/forum/brakes/41075...rotor-bbk.html
Really we should explore the possibility of fitting 350z setups in our cars since they share the same bolt pattern and aftermarket brake companies are infinite...
There are Z's with even 12 pot calipers!!!!!!!!!!!
Old 02-09-2009, 10:21 AM
Just in case the link doesn't work, here are the 6pot/4pot pictures.
Old 02-09-2009, 11:34 AM
sicksubie's Avatar
that option is available. I can get 6 piston Wilwoods made with no problem at all. It just comes down to what you want to spend. For that I would guess 1800-2000 for a set of 6 pot fronts... I can get firmer prices if you are truly interested.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
