Old 08-29-2010, 02:57 PM
Huskymaniac's Avatar
Uses the ignore feature
Fluid leak
It looks like I have a moderate leak near the front of the car. Best I can tell, it is dripping from the plastic cover. It has been sitting for over a week and there was a nice spot on the driveway. I think this is new or has gotten worse since I got the car. Any suggestions on how to pin down the source of the leak?
Old 08-29-2010, 03:02 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Fluid leak
Cam seals?
Manarius's Avatar
Manarius Manarius is offline
Re: Fluid leak
It would be helpful to know what kind of fluid it is. If it's brown, it could be engine oil. Red it could be either from the transmission or from the power steering. If it's green water, it's from the cooling system. If it's just water, it might be from the A/C.
-Jason
-Obi Wan Kenobi
Old 08-29-2010, 03:11 PM
Re: Fluid leak
Is it from the left, right, or middle of the cover? If it's the sides then it's most likely a cam seal. If it's the middle then probably the front main or oil pump seals. However, make sure it's no a leaky power steering reservoir dripping down onto things below.
Old 08-29-2010, 03:53 PM
Re: Fluid leak
It is hard to tell but it looks like a relatively clear or lightly colored oil. But the engine oil is looking pretty clean right now. But it doesn't seem as thick as engine oil. I will try to get a better picture of the oil and where it is dripping from. But the cover goes the entire distance of the front of the car so I'm not sure how the location matters.
The previous owner had the cam seals and oil pump changed when he changed the timing belt about 10K miles ago.
Does the tranny fluid level need to be checked with the engine running? I have read that the fluid should be checked when warm and the gear selector should be cycled through all the locations.
Old 08-29-2010, 05:09 PM
ZMan's Avatar
ZMan ZMan is offline
Re: Fluid leak
You could start by removing the cover!
Old 08-29-2010, 07:06 PM
kwren's Avatar
kwren kwren is offline
Re: Fluid leak
Sorry, can't place a "cover that goes the entire distance of the front of the car"
Got a pick??
Keith
Old 08-29-2010, 07:24 PM
Re: Fluid leak
Do you mean the skidplate/plastic tray piece? You won't be able to tell where anything is coming from with that on.
Old 08-29-2010, 07:34 PM
Manarius's Avatar
Re: Fluid leak
Follow the dirt trail and you'll see a lot (a lot easier on the lift though).
-Jason
-Obi Wan Kenobi
Old 08-29-2010, 09:03 PM
Re: Fluid leak
Yes, I think that is it. Does that thing have a critical purpose? Should I just take it off and leave it off? Maybe there is a reason for it to stay on like maybe it keeps salty water off critical parts in the winter.
Old 08-29-2010, 09:06 PM
kwren's Avatar
Re: Fluid leak
I would just keep it on the car... There are several reasons why it is on it!
Keith
Old 08-29-2010, 09:16 PM
ZMan's Avatar
Re: Fluid leak
Keith
OR - you can take it off, do what you need to do , then put it back on.
It's not that many bolts holding it up, why is everyone making such a big deal out of taking a simple cover off???
Old 08-29-2010, 09:17 PM
Re: Fluid leak
Keith
I suppose I should put mine back on, I just realized it has been off for about 2 years.
Old 08-29-2010, 09:21 PM
Re: Fluid leak
Taking it off is not a big deal. The question is, does it need to go back on and, if so, why. No big deal, I'm just curious.
Old 08-29-2010, 09:24 PM
ZMan's Avatar
Re: Fluid leak
Keith
One good reason to keep it off - at least in the summer: the transmission runs cooler!
