Old 08-14-2010, 09:07 PM
sicksubie's Avatar
Brake line question
I pulled the ABS unit out of my car and have a question now that I am starting to redo the hard lines. I have installed a non-abs master cylinder and running the two front lines will not be that big of a deal, but my question is can I just tie into the proportioning valve mounted on the pass. side strut tower for the rear?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-16-2010, 07:00 AM
sicksubie's Avatar
Re: Brake line question
Anybody? I am getting itchy to drive this and have it ready for the pumpkin carve meet in October..
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2010, 08:05 AM
NeedForSpeed NeedForSpeed is offline
I know nothing about it, sorry ,
please let us know how you sort it out
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-16-2010, 08:18 AM
Bobby, I'm not certain, but I think you need a different master cylinder as well.
You could ask LetitSnow, as he has Tom's old car which has the ABS deleted.
Old 08-16-2010, 11:09 AM
sicksubie's Avatar
I have the non-ABS MC already and have it installed. Did Tom use OEM non ABS lines when he pulled the ABS system from his car?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2010, 11:14 AM
How much does the ABS unit weigh?
Old 08-16-2010, 03:00 PM
Estimating from the ones I've lifted around, almost as much as a battery, about 25-30 lbs. The reason for eliminating it is partially for the weight, but more to eliminate the risk of the problem Tom had that caused him to get in a little fender bender when the ABS unit acted up...
Old 08-16-2010, 03:09 PM
That's a ton of weight to dump, considering the weight is out on the corner trying to make the corner!
What happened to Tom?
Old 08-16-2010, 03:11 PM
I was talking with The FlyingMoran Bros, at yesterdays Cumberland autocross, and on their 2500lb/400+ WHP Impreza, they not only kept the factory ABS system, but they had faster track times with it.
There is no ABS on The Racer now, so I'll take a look and call you, Bobby.
Old 10-15-2010, 03:36 PM
Anybody? I am getting itchy to drive this and have it ready for the Pumpkin Carve meet in October..
Its coming!
Old 11-06-2010, 06:48 PM
92SVXMan's Avatar
92SVXMan 92SVXMan is offline
Hey Everyone
Had the 92 svxlsi up on jack stands for a year, Driving a 04 Forester XT but its time to get the svx up and running again. Found a leak from the r/r inbroad of the sub frame and its runs over the sub frame, is there anyway to remove it easily? Can the pipe be removed without dropping the sub frame?
I have the FSM but all that shows is the pipes and hoses, it does not tell how to remove it from the car.
Any info on this job would be a great help
_______________
92svxman & Freida the co-pilot.
First 92 Claret(flat color,IMHO)
Two 92 Teal(much nicer color)
5 Speed pending, from 93 Legacy Turbo
4.11 Tranny/rear diff. May go for 3.90
Claret 145K
Underdrive Pulley from Newbies2005
New timing belt
new radiator
new water pump
new timing belt cover
New headlights and harness
Replaced exhaust (with stock)
Life on the road who could ask for more
Old 11-08-2010, 05:26 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Send a pic of the "proportioning valve" I have an abs and factory nonabs svx. In the non abs, the brake lines still run to a ...... something.... in the front passenger side of the engine bay, right where the abs module is. The abs car has the same dealy whopper. If that dealy whopper is the "proportioning valev" then yeah, you can use it. Lol, I hope this post helped more than hurt!
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
