Old 08-05-2010, 05:22 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
Little torque problem.
I have swap the car over to manual and after i just have stock clutch i have wait a little whit the Torque control on the ecu. But now i have take a jumper wire and i think i have done it rigth.
And i take the car out for a test drive. And its feel verry good. But some times this happen i press the pedal down and the car just hold the same speed in 2-5sec and its feel like a turbo start to go then its set speed. (Its only have happen i 1 and 2 gear)
What can this bee? i have a little exhaust leak can it bee this or are can it bee the jump wire its not coneckt right?
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 08-24-2010, 01:00 PM
Alex-svx's Avatar
Re: Little torque problem.
Some one have anny idea of what this can bee?
Alexander (Norway)
My subarus:
Old 08-24-2010, 02:36 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Maybe your throttle position sensor, the how-to for testing this is in the how-to's
Old 08-24-2010, 04:18 PM
It sounds like a slipping clutch from the description.
Do you have a cable clutch, if so loosen the cable.
(Not as tight.)
Old 08-26-2010, 11:04 AM
Alex-svx's Avatar
Yes i have Cable clutch. The clutch are not ''spin'' (i dont know the world for these) But i can also check the waier on the car.
But this can not bee the torque jumper, on the ecu??
Alexander (Norway)
My subarus:
Old 08-26-2010, 11:07 AM
Alex-svx's Avatar
I should look at this also.
Alexander (Norway)
My subarus:
