Old 07-28-2010, 06:49 PM
TheWheelMan TheWheelMan is offline
Radiator Q
Anyone know if you can fit any aftermarket STI/WRX aluminum radiators in the SVX?
Old 07-28-2010, 09:02 PM
Re: Radiator Q
They do NOT fit.
They are the right height, and the right width, BUT they have different fan mounts, the lower outlet and tank are in the wrong spot, the upper and lower mounts are also in the wrong places, BUT,
call me!
301-707-2827
TEEHEEHEE, snort!
Old 07-28-2010, 10:07 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Re: Radiator Q
The lower outlet is not in the wrong spot. STi radiator here fitting right up to the EG33 pump inlet just fine using the stock rad hose
as far as the other stuff, correct
Old 07-29-2010, 05:03 AM
Re: Radiator Q
Gee, the last two STI radiators that I bought from two different companys had the lower hose outlet about four inches farther to the left.
I'm not saying that the stock hose will not work, I am saying that the STI/WRX radiator will not fit.
Boxer do you have this in an SVX?
Old 07-29-2010, 06:58 AM
sicksubie's Avatar
Re: Radiator Q
They do NOT fit.
call me!
301-707-2827
TEEHEEHEE, snort!
Progress maybe???
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 07-30-2010, 09:31 PM
svxpert svxpert is offline
Re: Radiator Q
i have a stock 2004 STi radiator in my svx. its right behind the I/C. does that count?
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 07-30-2010, 10:39 PM
Re: Radiator Q
Did you have it modified?
Do you have any pictures?
Old 07-30-2010, 10:40 PM
Re: Radiator Q
I think he swapped the engine in order for it to fit
Old 07-30-2010, 10:47 PM
Re: Radiator Q
I just want to know if a "STOCK" anything can just bolt up to an SVX!
I have hundreds of dollars in trying to find a replacement radiator, THOUSANDS in transmission and brake parts, fuel injectors, MAFs,
the freeking list just DOES NOT STOP!
PLEASE God, don't tell Di!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!: eek:
