Old 06-27-2010, 11:01 AM
Gamesy's Avatar
Gamesy Gamesy is offline
sti clutch in wrx tranny?
does anyone know if an sti clutch will fit in a wrx tranny?
Old 06-27-2010, 11:17 AM
Re: sti clutch in wrx tranny?
Yep, but requires use of a die grinder to clearance some of the bell housing ribs. It appears that the only dimensional difference between the two is that the STi clutch is a little wider. See this thread on NASIOC.
Old 06-27-2010, 12:09 PM
Gamesy's Avatar
what about the stock wrx flywheel?
Old 06-27-2010, 01:05 PM
I'm pretty sure you'd have to use the whole thing together; flywheel, clutch, and pressure plate from the STi.
Old 06-27-2010, 02:31 PM
XT6Wagon XT6Wagon is offline
you need to be careful here. There is OEM STi 5spd and OEM STi 6spd clutchs, and flywheels. Then there is aftermarket versions of the pressure plates and clutch disks.
So being careful to ensure you get the right pressure plate and disk for the flywheel if you don't order them all together.
