Old 06-18-2010, 10:17 AM
crash_2365 crash_2365 is offline
Stereo Help
Ok, so when I got my car, it didn't have the factory sound sound system in it, and the wiring was iffy. I had a nice alpine HU laying around, so I decided to put it in. Started off working great. Then a couple weeks down the road, the sound randomly decided to cut out intermittently, usually when I hit a bump. So I pulled it out, cleaned up the wiring, re-installed, and it worked... for a couple days. Now it's gone completely. The head unit stays on, but all I get for sound is a pop from the RF speaker when I turn the head unit on.
I'm driving to PA in 6 days and I will just about shoot myself if I don't have tunes. So any help?
Old 06-18-2010, 10:40 AM
Wikedjuggalo's Avatar
Rebuilding
Re: Stereo Help
Well start with the basics, check the wiring isn't pinched behind the HU and also check connections. Check speakers and make sure your speakers are wired and not blown.
Old 06-18-2010, 11:06 AM
Cam Cam is offline
Re: Stereo Help
If it worked when you installed it and then stopped working I would say check all your grounds. It is possible though that a wire was pinched and was aggitated when you hit bumps, eventually wearing through the insulation and grounding the unit out. If everything checks out behind the unit, I would start checking grounds.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 06-18-2010, 12:59 PM
Re: Stereo Help
Got it!
I did check all the grounds and the speakers and their wiring.
Apparently the trusty ol' alpine isn't quite as trusty as I thought it was
Old 06-18-2010, 03:10 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Stereo Help
What you described sounds very much like a power stage short, caused by your speaker wires grounding or shorting together.
Old 06-18-2010, 03:24 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Stereo Help
Check your battery and alternator wires also.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-19-2010, 10:28 AM
Re: Stereo Help
Well I thought it was the HU itself but I guess that wasn't the case. So if it was a power stage short, do you think I should just run a new pair of wires to the each speaker?
Old 06-19-2010, 10:33 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Stereo Help
You can do a quick test from the head unit.... use a multimeter to check resistance between the pos and neg wires going to each speaker. If they have continuity, then they are shorting together. You can also just disconnect one speaker lead pair at a time until the unit stays on, this can also pinpoint a short.
Old 06-19-2010, 04:11 PM
Re: Stereo Help
I would just run new everything...that's what I did.
But that's just me, and I am overkill.
See:
http://www.subaru-svx.net/forum/showthread.php?t=54516
And then again, it did turn out my trusty pioneer HU was dead..
Old 06-19-2010, 04:24 PM
Re: Stereo Help
+1. If you can't trust it then what good is it? Also, make sure to cover the ends of any wires you leave behind, or just remove them altogether.
