Old 06-15-2010, 06:15 PM
zaueugen's Avatar
zaueugen zaueugen is offline
how do i solve the water spots that show up in the taillights
Old 06-15-2010, 06:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: how do i solve the water spots that show up in the taillights
I fixed mine with new foam gaskets from subarugenuineparts.com, and used silicon to seal around the seams and tabs.
Old 06-15-2010, 07:04 PM
I heated them up so that I could separate them. Left them open for a day or two, then heated them back up to put them back together. Then cleaned off the existing rubber seals and also used black RTV to ensure they were sealed up completely. Haven't had a problem since on my silver. Just need to do it to my other SVXi now.
Old 06-15-2010, 07:33 PM
Manarius's Avatar
Manarius Manarius is offline
Bake to get the water out. Electrical tape around the seams to keep the water out. Kind of ugly, but gets the job done.
-Jason
-Obi Wan Kenobi
Old 06-15-2010, 07:58 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Oh forgot....... the quickest way is to prop a blow-dryer to aim in either bulb hole and just leave it on high for a bit. Mine cleared out in about 30 minutes. THEN reseal them to keep the water out.
Old 06-15-2010, 08:24 PM
I would use something clear rather than something black like RTV, just in case it ends up being visible when you put everything back together. Clear silicone would be my choice. It's on my list of things to do as well... headlights though.
Old 06-15-2010, 09:02 PM
How's it going to be visible? It goes in between the back of the assembly and the body. Its just there to help with the seal along with the existing rubber "gaskets".
Old 06-15-2010, 10:00 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Take apart the assembly, take out the defusers, reassemble the lights..
It seems like they keep getting stuck behind the defusers and removing them entirely might solve the problem... They look cool too.
Old 06-16-2010, 12:41 AM
In case it get somewhere it shouldn't. Seems safer to me is all.
Old 06-16-2010, 01:07 AM
Guess I'll have to show you pics next time I do it.
I don't see any way that it could get somewhere it shouldn't
