Old 06-15-2010, 12:33 PM
Question about Glove Box Door
So yesterday the passenger in my car noticed my glove box door seems to be out of wack. Looks like it doesn't close all the way.
Is this normal, or is my glove box door broken?
If this is broken, what do I need to replace, the whole box? Or are the hinges part of the door or the box itself?
Old 06-15-2010, 12:39 PM
RSVX RSVX is offline
Network Design Administrator
Re: Question about Glove Box Door
Normal....
Life is a game. Play to win.
Old 06-15-2010, 03:09 PM
My glovebox on my 96 polo fits perfectly flush with the dash on both sides. It was also the same on my 92 pearlie.
No sagging or gaps at all.
Looks like someone tried to pry into a locked glove box. Definitely not correct.
Old 06-15-2010, 03:31 PM
^^^ Ditto what John says, mine closes perfectly.
Old 06-15-2010, 04:48 PM
So is the door & hinges separate pieces, or do I need a whole new box?
Old 06-15-2010, 05:12 PM
Probably just a new door. You should be able to reuse the hinges and your lock/latch.
Old 06-15-2010, 05:53 PM
kwren's Avatar
kwren kwren is offline
Take it off and you should be able to see what is going on with it and straighten it up...
Keith
Old 06-15-2010, 10:35 PM
New glove box doors are $320.00
Definitely get a used one from someone parting out. Over time, the gray should have faded as much as yours, so the match should be perfect. You may be able to bend it back into position.
Have no idea what color a new gray door is.
Old 06-15-2010, 10:39 PM
By "new" I meant a used one from someone... aka, new to him. Guess I should be more clear. I do have one if you like...
Old 06-16-2010, 06:48 AM
WTH... my car must have been screwy then...
