Old 06-14-2010, 05:07 AM
Gamesy's Avatar
Gamesy Gamesy is offline
manual clutch pedals
Does anyone have a pic of the clutch pedal assembly done to the svxs? i need a better understanding of what to do aside from the how-to
Old 06-14-2010, 06:44 AM
Re: manual clutch pedals
Gamesy, start checking the lockers of those who did the conversion.
Better start with YT..
Old 01-08-2011, 02:44 PM
fluo fluo is offline
Hi guys.
I converted my SVX to manual transmission in 2009. I used a legacy turbo transmission, pedal assembly and a hydraulic clutch system. It works fine, but its not perfect, because the pedals arent in a good position. To prevent trouble with the gas pedal, I installed an adapter between the pedal assembly and the firewall of 1.2inch. Now, I want to make it better, because I cant fill the hole in the firewall and I want the pedals all in one line. The problem is, that when i remove the adapter, I will get problems with the gas pedal, because it will bump on the rod for the clutch. Can someone help me , who did the same conversion and solved this problem?
Thanks in advance!
PS.: sorry for my bad english, hope you can understand everything
fluo
Old 01-08-2011, 02:55 PM
The gas pedal in my car has a plate that shifts it slightly down and to the left. That seems to be the key to my pedals all working together. The clutch/brake pedal assembly looks to be from an STi and is hydraulic.
Old 01-08-2011, 02:57 PM
Gamesy's Avatar
shorten the the rod on the gas pedal so it doesnt interfere,
i have mine coming off the the firewall which i prefer cause i have issues of the clutch pedal hittin the firewall
Old 01-09-2011, 02:45 AM
Thank you guys!
Now, I can finally complete the manual transmission swap.
fluo
Old 01-11-2011, 03:42 PM
Pic of the adapter plate in my car:
Old 02-06-2011, 04:18 AM
thank you, i think, i will do it like you have done.
greetings
