Timing belt service interval
I've only had my 92' svx for a few months now. And I was wondering
what the replacement interval is for the timing belt. One of the service recipts from the previous owner, showed it being replaced at around 120k. It has 147k on it now. Thanks. |
Re: Timing belt service interval
Every 60K miles is the schedule for it. However, the EG33 is a non interference so if it fails, it will not damage the valves.
The service intervals are in the How-Tos so you can see what is done and when. I would say that your SVX is ready for a new timing belt. While you are in there, you should replace some other things. The water pump and thermastat for example. You are already in there, so this is a good time to do it.
The belts will last longer than 60,000 miles. California mandates that timing belts last 105,000 miles. I changed the timing belt for the first time in my 1996 Polo back in 2008 at 122,000 miles. The belt looked perfect and had all of the original markings still visible. Still replaced it anyway because the original was 12 years old. New water pump and thermostat are essential, since they may not have been replaced at your last timing belt change. New Subaru OEM is best; not too fond of the rebuilt units. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 09-19-2012 at 03:15 PM. |
Resurrecting this thread from the dead. I have seen the quoted service interval of 60K miles. I also saw a third party service interval suggest 105K miles. Most new cars, interference and all, suggest 100K or 105K.
What do the experts here say? I understand that it is common practice to replace a lot of other stuff when you do the timing belt. It would seem overkill to replace the water pump every 60K miles. For those that do the timing belt every 60K do you replace the water pump every 60K also or, say, every 120K miles or every other timing belt change? Or do people do the timing belt every 100K or so and do the water pump and assorted pullies and seals at the same time, every time? And the service intervals for diff oil and ATF are equally confusing. It says, for severe conditions, that the ATF be replaced every 15K and the diff oil every 30K. But there is NO interval specified for normal conditions. I had always heard ATF should be replaced every 30K and I assume that was for more "normal" driving conditions. I have opted for a drain and refill that I am doing every 12K. Given how much drains out, it works out to be roughluy equivalent to a full change every 30K. If I towed stuff or did a lot of hill driving I would probably cut those in half to be inline with the "severe" interval mentioned above. Does that sound about right? And how about the diff oil? What do people normally use as an interval for normal conditions? 30K? 60K?
Incidentally, it's 100k km _OR_ ... five years
I got my girl, I got my glass, I got my car and I'm ready to f... |
The SVXi that I have service history from and were dealer maintained have had the belt and pump done at 60k miles, or thereabout. Take a look in the "what have you done to your SVX" thread to see what happens to a water pump that seized up at 88k miles. Considering it's only an extra $120 plus an addition hour or so of labor, it's worth getting it done so that 10k miles later, it doesn't take out everything you've just done. Also, most shops won't warranty a timing belt failure if the pump seizes. I also do all of the idlers everytime. The seals are 50/50 and depends if they're leaking. If they're not leaking, I won't touch them.
As for trans fluid, I stongly suggest 30k miles max before a drain and refill with a filter change. (I realize there is debate about the filter) A lot of people do a drain and refill of the trans fluid every other or every 3rd oil change as well. Doing it more often definitely can't hurt. As for differentials, wouldn't hurt to change them every 60k miles or so. I've seen plenty that I'm sure were original when doing 4.44 swaps and normal service with well over 100k miles. |
Also, I'd like to add that I have seen mentioned several times on both forums, water pumps seizing near the 120-140k mark. My black 97 for example was very well maintained but the water pump was not changed at 60k when the timing belt was. Then at around 130k it seized and shredded the timing belt (and then I got the car). So 60k miles might be a little overkill for the water pump, but that's why it's called "preventative maintenance", after all. So better to change it at 60k than have it fail right before 120k, when it would get changed at the 2nd timing belt.
