#1066
Re: SVX Engine cooling "Again & Again"
Oops. I forgot all about Tom's revised, and enlarged crossover pipe. The radiator inlets and outlet adn the hoses are stock size. Here is the list of modifications again, corrected.
1. Enlarged and revised coolant crossover pipe 2. Thermostat relocated from water pump inlet to radiator inlet hose. 3. 160 DegF thermostat 4. 175 DegF fan acutation setpoint.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#1067
Tom |
#1068
I can see many welds on the left side pipe, does that mean you welded the pieces according to manifold clearance? So it is not a perfect pipe...
#1069
And in my view, not true dual pipes like the Tribeca...
#1070
Ahhh, but it seems to work. It was such a pleasure not having to deal with overflowing coolant every track session.
#1071
Touche...but dual top pipes would be like the following. I wonder if that would make any difference.
I'd love to know what the difference was between yours and my experience. By Sunday (our time) I expect to have an update for you from my perspective....45mm bottom hose and no thermostat. M |
#1072
Danny, did not have a long enough piece of 1.5" tubing to make the straight shot. So I built one with what I had... If was a one off idea that we did not know if it was going to work or not... Just had to try it.
Matt, the purpose of the pipe was not to create a dual outlet but to move the merge away from the R/S outlet and further downstream to where if one bank were to have an opposing pressure a venturi would help equalize flow, pressure, and velocity. When I built this, it was on the premise that the flow for both banks was not equal and causing the L/S bank to run warmer than the right. Also, running no stat is not a good idea. Yes it might keep the engine from overheating but the longer it takes the warm up, the more fuel you are pumping into the cylinders w/o a need. Relocating it to an outlet allows you to get rid of the cycling from the head, retain heat, and create the ideal system to control a running temp rather than just keeping it as low as possible Tom |
#1073
Thanks for the points.
When Harvey mentioned dual system, I envisaged the later H6 setup with dual top pipes to dual fittings on the radiator. I'm a fan of reusing Subaru's ideas in some cases as I expect they have more development dollars than me. No thermostat in a road car I would agree...in the rally car, fuel usage isn't so much of an issue. Thanks, Matt |
#1074
It shouldn't be overlooked that YT also tapped into the heads at the bosses for the front two cylinders on each head and ran hoses to the custom crossover pipes!
-Bill
#1075
To |
#1076
Interested to know if that would make the temperature the same all over the cooling system
#1077
#1078
Old Tom:
Sent you a PM. Please check. thanks. Dan
#1079
Tom |
#1080
I saw it a little while ago tonight, Dan.
I will check into it. Thanks. T
