Old 05-18-2011, 02:56 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Memory dump of ECU
I haven't done much with this project for a while, apart from building some custom TCUs with special shift maps.
Somebody just sent me a new software called JECScan that can log ECU and TCU parameters, and download the ROMS to a file. It's on my website for download if anyone wants to try it.
This is currently the only windows software that can download TCU rom.
I've also got some information on communicating with the cruise control unit. It uses an older protocol designed for the L-series (Leone). It needs a modified interface and special software to communicate. I'd like to make it work just for completeness, but I don't see anybody ever using it.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-18-2011, 06:17 AM
Huskymaniac's Avatar
Uses the ignore feature
Do you get this data through the OBD port?
My son just bought an android phone and I am toying with the idea of him writing an application that can pull the Subaru Select Monitor data. There are lots of applications out there that can get OBD and OBDII data and some that get some SSM data but I haven't found one that can get the TCU data.
Tony
Old 05-18-2011, 06:51 AM
b3lha's Avatar
Phil & Belha
Yeah. Through the SSM connector on OBD cars. May also work on OBDII with the right cable.
I hear android runs java, so FreeSSM may work with a bit of tweaking. Maybe also ECU Tracker (formerly called JDash).
Old 05-18-2011, 06:55 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
If you made it for android, consider me your first customer.
Old 05-18-2011, 07:15 AM
Don't those programs only get some of the SSM data?
Tony
Old 05-18-2011, 07:33 AM
If I can convince him to do it, I was planning on having a few people here beta test it.
Tony
Old 05-18-2011, 08:19 AM
b3lha's Avatar
Phil & Belha
As far as I remember, FreeSSM has a definition file where you tell it what parameters you want to read and how to decode them. I know that Frank, the developer, was pulling the addresses out of a real select monitor to make sure he got them all.
It was still a bit experimental last time I tried it. I may have another go soon.
Old 05-19-2011, 02:50 PM
longassname's Avatar
Just some dude.
Will my interface work for you?
Old 05-19-2011, 03:07 PM
Just some dude.
I posted the definitions file I created for my ECUtuner software earlier on in this or one of your other threads. It includes all the Subaru Select Monitor parameters which were obtained directly from eavesdropping on the coms between an SVX ECU and genuine Subaru Select Monitor. It also includes most everything I found of interest in the ROM for tuning and modifications and a few things you had mentioned as well. It's still on the website at http://www.ecutune.com/posts/definitions.xls
Old 05-20-2011, 02:31 AM
b3lha's Avatar
Phil & Belha
No. I need to generate a 250 hz clock on pin 4 with -5v to +5v pulses. I can generate the right signal with the FTDI interface in bitbang mode, but only between 0v and 5v.
I think I need a voltage inverter to create the -5v and a comparator to toggle the signal between -5 and +5 as the FTDI toggles between 0 and 5.
Old 05-20-2011, 02:32 AM
b3lha's Avatar
Phil & Belha
Did you ever release that software? I thought you had given up on it?
Old 05-20-2011, 06:34 AM
Just some dude.
I just stopped working on it. I will presumably continue with it someday and release it (open source) so I can sell the interfaces I have sitting on a shelf (complete with select monitor harnesses).
Old 05-20-2011, 05:32 PM
b3lha's Avatar
Phil & Belha
I just bought another SVX ECU for research and it wasn't quite what I expected. I think it's a very early USDM version, label is D1 rather than the usual M7.
The circuit board is slightly larger (see photo). The D1 is on the left compared with the regular D2 from my JDM on the right. The small chip in the top left corner is external ROM. I guess that when this ECU was made, the M37791 MCU wasn't yet available in a 32K version, so they had to use external.
The original firmware is 722521. At some point it has been upgraded with a chip containing the 1993 firmware 722527.
I compared the 722521 firmware with the USDM 92 firmware 722525. The timing maps and MAF scale are the same but the fuel map is very slightly different.
Old 05-24-2011, 04:19 PM
Will this / or could you eliminate the speed Governor that restricts top end ?
Old 05-24-2011, 04:36 PM
No SVXes have governors. There's nothing in the ECU or TCU that limits the top speed.
