  #31
Old 08-10-2013, 12:42 PM
BackWoodsBob BackWoodsBob is offline
Re: twin TD04 project
Originally Posted by BackWoodsBob View Post
Found 2 td04's for <150 each. Thinking of running them both under the car. Swap the manifolds side to side, rotate them, bolt the TD's up, run an oil filter sandwich plate which would effectively feed and draw oil from the turbos, T off a coolant line and go to down.
Only problem is the MAF, which, if I'm correct you could just swap straight with an MAP sensor without issue.
instead of removing the maf I'm going to use it for tipin enrichment, seal it against boost and clamp it.
Old 08-10-2013, 01:32 PM
Tireiron Tireiron is offline
Most systems run the MAF before the turbo anyway so they don't see boost. The problem is then you would have to Y the intake to both turbos unless you can tune the car and run 2 MAFs, 1 for each turbo inlet. Going to a MAP system with the hydra or megasquirt eliminates that issue and allows an air filter to be stuck at each turbo inlet and be done with it.
Old 08-10-2013, 03:58 PM
Ineed, however, going with a 2:1 intercooler, run the MAF inline with that one tube to the throttle bodies then Y it off right before the throttle inlets. This way you can use the MAF off-boost and use it for tip-in enrichment, then clamp it off as boost rises.
Old 09-10-2013, 09:18 PM
Gamesy's Avatar
Gamesy Gamesy is offline
back in ontario with my svx so now i will be starting my TT svx project.
ordered the gasket rebuild kit for the spare engine, now i need to source pistons and rods for the build
Old 11-09-2015, 04:00 AM
Billsy Billsy is offline
so any news on this?
seems everyone with this low mount twin td04 idea fails or gives up.
Old 11-28-2015, 11:56 PM
Gamesy's Avatar
lol since this post my svx water pump went and cracked the housing, got a 2nd svx while i rebuild the laguna, moved across country so i'm a little behind lol
i've talked to a few people and TD04's are still too small even for a TT setup.
so since i need to rebuild my engine, i'm going full build from the ground up might run something like twin GT35R's
I will document the build once i get around to having spare funds for it.
Old 11-29-2015, 07:58 AM
GT35's?! What kind of power are you shooting for with those?
I've always pictured a pair of GTX28's with V-band housings... Mmmmmm...
Old 11-30-2015, 02:39 AM
twin 35r's cmon. we can get 700HP out of 1. that and there too huge to fit low mount.
2 td04's will comfortably break 400hp atw.
good to hear you havent given up though.
a 1000hp+ svx would be absolutely epic though if you do fit 35r's
Old 02-28-2016, 12:11 AM
Gamesy's Avatar
my goal is to be in the 600 range, twin td04s wont be enough.
i'm gonna get the deck fully closed.
Old 02-29-2016, 05:59 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
A couple of VF39's will certainly meet your needs.
Even a single TD04 pushed to max will make 280 whp on a 2.5 Suby. That's theoretically 560 whp with twins.
Bob Légère
EG33 Impreza tweaks
Old 03-10-2016, 03:28 AM
my choice would be twin vf34 if aiming for 600ish. or 2 GT2860's wit hth e .6 rear housing or similar. though the garretts have a much bigger housing to fit in underneath.
