Old 01-06-2013, 09:55 AM
michael's Avatar
michael michael is offline
What Potholes ???
3.3 vs. 3.6 Exhaust Manifold Gaskets
Has anyone ever compared the two?
Wanted: Steering Wheel
Old 01-06-2013, 11:44 AM
bishop bishop is offline
Re: 3.3 vs. 3.6 Exhaust Manifold Gaskets
completely different
Old 01-08-2013, 01:09 PM
The EZ30 and EZ36 are tiny in comparison to the EG33 and nothing would be compatible. Why are you asking? It's not like the stock gaskets are expensive.
Old 01-08-2013, 04:37 PM
michael's Avatar
What Potholes ???
There are a lot more options for 3.6 headers.
http://www.saunalahti.fi/boiv/Tech%2...eaders%20I.JPG
This pic got me thinking
Old 01-08-2013, 07:04 PM
http://www.svxworldforums.com/view_t...hlight=headers
Old 01-09-2013, 08:18 AM
Originally Posted by bishop View Post
I might make a set similar to these during the summer. Need to get myself a MIG first (my current flux core machine sucks), but it would be a fun project. I've got a spare set of stock manifolds sitting around so it would be easy enough to make a jig.
Old 01-09-2013, 09:28 AM
wondering how hard it would be to have an exhaust custom built back from the outback headers, they look like they would have the best flow.
Old 01-09-2013, 10:34 AM
It would definitely be doable. Both YT and OT (TomsSVX and svxfiles) have built equal length headers for their cars. My goal would be to make it a direct replacement for the OEM manifolds though, so people would have the option of replacing their exhaust in whatever stages they wanted. Long tube headers would require people to also replace the rest of the exhaust.
Old 01-09-2013, 11:36 AM
Problem is, unless you do long tube headers, there are minimal, if any, gains to be had.
Old 01-09-2013, 11:51 AM
True enough, not much advantage without changing the flow. Still for myself the bling factor, weight reduction, and fun of making them would be enough.
Old 01-09-2013, 07:45 PM
if there is little to no benefit why are there claims of 20hp from a highflow cat, resonator, and muffler upgrade?
Old 01-09-2013, 08:16 PM
Show me a dyno sheet... Claims are just that...
Also, we were talking about the possibility of headers.... That has nothing to do with anything you mention.
Edit: Also, due to the IRIS intake of the EG33, while you may increase hp at certain ranges, it needs the exhaust to be just right or you will lose a LOT of low end torque.
Old 01-11-2013, 04:34 AM
Darren's Avatar
Darren Darren is offline
There is always a trade off with so called BHP increases from exhaust systems, other factors are effected like torque,heat, fueling, noise and when the power and torque is available in the rev band.
Manufacturers and after market exhaust companies spend hundreds of hours and thousands of pounds/dollars on R&D to design a system for a specific purpose.
I have yet to find anyone who has managed to build a properly balanced system with off the shelf cut and chopped parts in their garage or driveway. An exhaust system alone is not going to make any noticeable difference when you drive the car. As for weight...it's an SVX, enough said really!
If you want a loud exhaust on an SVX maybe you should be looking at buying a civic or skyline? Or as you are lucky enough to have lovely V8's you are spoilt for choice on the decibel front.
Just saying :-)
Darren
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
