Old 11-07-2007, 08:09 PM
NiftySVX NiftySVX is offline
Pulling Motor
I am approaching 120k and would really like to yank my engine out and give it the old once over (valve cover gaskets, front seals, hoses, etc) but i really don't want to open the refrigerant system since this is never a good idea... is there a way to suspend the a/c compressor out of the way and still get the motor out? If there isn't, I will probably just do the stuff with the engine in the car. which means I will do less than i would like.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 11-07-2007, 08:14 PM
I just saw a picture of that a couple days ago. You can unbolt the compressor and swing it to the side while still keeping the AC lines attached. Just be careful you don't bend anything.
Edit: Here you go, borrowed this from svx_commuter's locker:
Old 11-07-2007, 08:18 PM
AlcyoneDaze's Avatar
<-- custom hood ornament
why such a bad idea to open up the AC system?
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 11-07-2007, 08:22 PM
The worst thing you can do is open the system. If you do, you have to replace the receiver/dryer as the desiccant becomes saturated from the moisture in the air in minutes, and you have to replace o-rings (which can be hard to get in the correct size) not to mention that contaminants can get in the hoses, and I don't want a clogged expansion valve or a bent compressor valve.
