Old 04-13-2014, 08:25 AM
Tapani Tapani is offline
Re: Front Dif issue?
Check the tranny code close to the starter and there might be a sticker in the diff cover at the rear.... if not, the only way is to drain the oil and count ring gear teeth thru the filler plugs. Mark one with a chalk or marker and then rotate SLOWLY to count the teeth.
/T
Old 04-13-2014, 09:22 AM
This is a picture of the transmission # location;
http://www.subaru-svx.net/photos/use...svxfiles|24636
Old 04-15-2014, 04:52 AM
GRN_NVY's Avatar
GRN_NVY GRN_NVY is offline
Can you post the transmission number?
Black letters/numbers on the drivers side bell housing by the starter.
Found 2 numbers:
TZ102Z2ABA
942301
Haven't had a chance yo get under the car yet, no stands. Weather turning crappy again too.
Old 04-22-2014, 06:18 AM
GRN_NVY's Avatar
In a FWD a 4.44 would be a tire smoking bummer of a car to drive.
It could be an axle, easy and cheap to replace.
To convert to AWD you need an AWD trans,
a driveshaft,
an AWD rear subframe,
a rear differential
and a bunch more labor.
I've had 2 mechanics and an SVX owner rule out the "axle" theory. I don't know what this "rear subframe" is that you speak of, but the PO appears to have done all the stuff cuz it has a rear diff and the tranny was coded 4.44 (probable) by a member of this forum. I actually recorded the sound it makes, but apparently sound files (.mp3/4) are not acceptable extensions, so I can't upload for all to hear.
Old 05-27-2014, 06:35 AM
GRN_NVY's Avatar
Hi all,
Just wanted to post an update on my tranny issue. The noise was indeed coming from the front diff, and yes, my tranny is a 4.44! The drive gear in the diff and the "worm gear" from the tranny both have broken teeth. My mech says it's a possibility the dif was run without lube. The replacement tranny is from a '97 Legacy Outback and installation is being wrapped up as of this writing. I will attempt to post a couple of pics, but, I haven't gotten the hang of that yet. Anticipating the "release" of my rig today or tomorrow. I want to thank everyone who took an interest, and offered advice and encouragement! You know who you are, Thank You! . Hope everyone had a happy and safe memorial day holiday!
~I hear and I forget, I see and I remember. I do and I understand~
1994 Subaru SVX LS_Color: "Infinity/Emerald Mist"
My Other Ride is a Sailboat: San Juan 7.7M
Formerly owned 3 Subie XT's
Old 05-27-2014, 12:37 PM
Well I would say u found the problem.
I did not think the 97 outback was a 4:44
Old 05-27-2014, 11:15 PM
GRN_NVY's Avatar
I was advised by another member that the '97 "Legacy" outback would be a good match for the swap and would be a 4.44. Another step closer to becoming a card carrying SVX "Road Ranger"
Old 06-09-2014, 09:19 AM
GRN_NVY's Avatar
New tranny is in, We're Rollin'! Total cost of repair:
97 Legacy Outback 4.44 $390 delivered, 1 year warranty
R&R Transmission $400
Peace Of Mind "Priceless"
Old 06-09-2014, 04:06 PM
Good to hear. Welcome to the club!
Old 06-10-2014, 06:54 AM
GRN_NVY's Avatar
Thanks! Happy to be aboard. Had the car detailed Sunday, getting her ready for The Dragon meet at the end of the month. This will actually be my second time in attendance at The Dragon, but the first time in my own vehicle. I'm really Psyched about it.
