Old 03-13-2011, 10:38 PM
Wiring harness and what else for EG33 swap?
Hi, so I'm about 90% done stripping my parts car. I pulled out the giant mass of wires that connects to the ECU, engine, etc. That's what's called the "wiring harness" right? Which people tend to part out SVXi to get for EG33 swaps into other cars, right? What else should I grab that's needed or helpful for an EG33 swap into another car? (other than the really obvious like the ECU)
Old 03-14-2011, 12:43 AM
Old Fogey
Re: Wiring harness and what else for EG33 swap?
Possibly dash harness. I'd be sure I had the piece of harness that ties the ECU in as I doubt it'll run in anything else without it. My $.02. I looked at smallcar site, and they mention the harness, including O2 sensor wiring.
Glenn
Old 03-14-2011, 05:21 AM
michael's Avatar
michael michael is offline
What Potholes ???
MAF Sensor.
Wanted: Steering Wheel
Old 03-14-2011, 10:25 AM
Glenn
It plugs into like everything. ECU, engine, ABS, I think the airbags, basically everything at some point.
Got a couple MAFs.
Old 03-14-2011, 12:04 PM
httrdd httrdd is offline
What are you swaping into? I know you need the bulkhead wiring harness, ecu, main relay, fuel pump relay, maf, air box (unless you custom something), power steering hoses (low and high pressure)..... If it is an auto you need the torque converter from the swap car (mine was Legacy GT). I am sure there is more I am not thinking of.
Old 03-14-2011, 12:15 PM
Thanks that's exactly the kind of info I needed. Where are the main relay and fuel pump relay?
I'm not swapping it, but I've gotten interest from other suby guys for an EG33 swap so I want to be able to sell it as a set. I'll offer it up here too.
Old 03-14-2011, 02:19 PM
They are next to the ecu.
Old 03-14-2011, 10:53 PM
Got em. I should have pretty much everything then. It's now nearly 100% stripped. Pulled everything but the airbag computer and the heater core, since they seemed like a pain.
Old 03-15-2011, 06:14 AM
Grab the igniter too.
