Old 10-10-2011, 01:46 AM
aust92pearl aust92pearl is offline
Re: oddness of my oddity is being odd :/
Originally Posted by flamestone View Post
Just in case it helps... the guys I got my replacement engine from probably still have the gearbox. Had only done ~80000km.
thanks mate if it is damaged enough to need a rebuild or new tc il just find a manual box and convert it , i might have actually found a gen 3 lib 5 speed donor car , so il see how things pan out
Old 10-10-2011, 05:47 PM
dynomatt dynomatt is offline
If you get the Gen3 one you can also use the tailshaft from it. That's what I put in when I went to the 5 speed.
M
Old 10-11-2011, 01:12 AM
M
oh ok sweet that makes things a bit easier
i was kind of hopeing dad wouldnt have to shorten or lengthen (whichever it needed) the stock svx one
thanks for the tip matt
Old 10-11-2011, 11:04 PM
well just went and saw the mech ... turns out it is literally stuck in 3rd gear it stalls in every other gear and basically almost does in 3rd aswell he managed to get it to drive around the block (a few hundred meteres) and it didnt change gears up or down or even attempt to do so , as well as the torque coverter being locked constantly .
so looks like il have to get this 5 speed im looking at
still dont know how or why it decided to just lock up like that though, unless the breakdown of the tc somehow made it stick in 3rd aswell ??
Old 10-12-2011, 07:16 PM
got the car towed back home , tried a few other things (removed the resistor thats beside the battery, didnt make a difference just showed the code for it , tried removing the maf plug when running and it stalled out ,
looked at everything i could see and noticed a little vac hos under the manifold that goes from a little connection bit behind the a/c to the iacv (i think) has broken away from the iacv .
would that cause the car to stall out when a gear is selected ??
also noticed when trying to put it in gear the tc doesnt seem to be locked anymore which it was before and would make a loud clunk noise , now it doesnt make the cluck noise just stalls out
il try to remove the vac line and replace it tomoro before work and see if it stops the stalling out
Old 10-12-2011, 07:59 PM
To test the MAF, you unplug it before starting the car. If you unplug it, it suddenly stops reading air flow, so of course it will stall. If the ECU knows it's not there when it starts, then it knows to just ignore it.
Old 10-13-2011, 01:13 AM
i tried that as well, it stalls after about 3-5 sec without it plugged in
Old 10-13-2011, 08:10 AM
well i won a gen3 5 speed liberty for $1525
yay
now i just gotta work out payment and when i can afford to pick it up and hopefully i can get it in my pearlie by mid next year or sooner
Old 10-13-2011, 07:03 PM
if the tc wasnt installed correctly and the pump was damaged would it work fine for a while say 800km (500 miles)then start to play up then stop working all together before it reached 1000 kms (600 miles)
just trying to find possible causes for my trans to take a dump
not that im terribly worried about it now that i will have a 5 speed in it in the near future would just like to work out how what and why
