Old 04-25-2012, 08:49 PM
STiLtd683's Avatar
STiLtd683 STiLtd683 is offline
Cylinder pitting
Hey all,
I found some light pitting in several of the cylinders in my latest block. I've rarely heard of them in flat engines and I was curious if any of you had run across this issue in an EG33. Thanks.
'94 SVX
'92 SVX
Old 04-25-2012, 10:47 PM
Cam Cam is offline
Re: Cylinder pitting
I have only seen the inside of one, but you could still see the crosshatch and every cylinder was true and round. Surface quality of the cylinders was surprisingly good. It had nearly 200k miles.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-25-2012, 11:28 PM
^The one I dismantled looks like this. Seems perfectly fine.
Old 04-26-2012, 12:29 AM
STiLtd683's Avatar
I have terrible luck with EG33's. I'm on my third block. Hopefully this is just surface marring and I can do a light hone and get rid of it. I'm trying to avoid dropping a lot of money on the car right now. Getting married in October.
'94 SVX
'92 SVX
Old 04-26-2012, 10:13 AM
you have a k&n or similar air filter? that's the only time i have seen it.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-26-2012, 01:57 PM
STiLtd683's Avatar
I'm not sure. This engine came out of a parts car I just picked up and I tossed the filter without really looking at it.
'94 SVX
'92 SVX
Old 04-26-2012, 02:00 PM
only ones i have seen with cylinder wall pitting without other signs of detonation such as pitted pistons have had a k&n or even worse the plain foam ones. i would just get it rehoned if they aren't that deep but if they are deep you may want to rebore.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 04-26-2012, 02:45 PM
STiLtd683's Avatar
Boring it out is what I'm trying to avoid. Pistons are expensive
'94 SVX
'92 SVX
Old 04-26-2012, 05:35 PM
oab_au oab_au is offline
If the pitting is up at the top 30mm of the bore, it will is not good. If it is just light small pits down around the bore It won't worry it too much, just hold some oil.
When I was building two-strokes, I allowed the bore to rust, before honing to form the small oil holding pits.
One Arm Bloke.
Tell it like it is!
Old 04-26-2012, 05:50 PM
STiLtd683's Avatar
That is fantastic to hear. It looks like it is only at the bottom.
'94 SVX
'92 SVX
Old 04-26-2012, 06:21 PM
I would just do a light hone to smooth the surface, don't try to hone them right out.
One Arm Bloke.
Tell it like it is!
