overheating
So I was driving from Portland back to Corvallis and my car started overheating. Not knowing what was wrong I had it towed to the nearest dealership. Now they tell me that I need a new trinary (spelling?) switch, which they say will cost around $700 to replace because they need to get new pipes or something along those lines. I don't know much about the cooling system so my question is. Does this sound about right or is something fishy going on?
David '94 Laguna Blue L 110,000 5000k Hid's, K&N drop-in filter, leather seats(thanks to mysvxrocks), 350z rims, and now with big dent in rear passenger quarter panel Purchased 12/2007 and lovin it [SIGPIC][/SIGPIC] |
Re: overheating
Trinary switch? I've never heard of such a thing.
Re: overheating
Yeah they sound like theyre taking you for a ride, get a second opinion. Have you even checked your coolant level?
Re: overheating
Trinary??!! Sounds fishy... Look, check your fuses first, if the cooling fan fuses are broken, then there is the problem, if they are ok, turn your engine on, check the coolant level and replace the cap, let the engine warm up to normal operating temperature, if the big radiator hoses are still cold, then maybe the problem is the thermostat, if they are hot, then go get a second opinion.
95´ Subaru SVX EURO 85' Mercedes 190 2.3-16 86' Mercedes 190E 70' Olds Toronado 98' Renault Chamade 82' Honda Prelude 79' Honda Accord awaiting restomod. 69' Mustang Hardtop 67' Jeep Ford Willys awaiting restoration. 67' IKA Torino Coupe 74' Renault Torino Coupe |
Re: overheating
The coolant is full and the fans are not working. I'm going to pick the car up tomorrow. Someone I told the symptoms to said it sounded like a broken thermostat.
Re: overheating
Let me come have a look at it, if what they are referring to as a trinary switch is the thermoswitch that controls the fans, that can be fixed for a whole lot less than $700! I'll be back in Corvallis Wednesday evening.
