  #46
Old 05-03-2010, 01:08 PM
Re: building engines and turboing 2 svx's woot woot!
Hmm, interesting. Seems like that would always affect the structural rigidity in some way, wouldn't it? Sure would make the cramped engine bay a lot more flexible though. And it would have to be welded in? (bolting not an option?)
Old 05-03-2010, 08:24 PM
Banned
the purpose of pipe or beam etc is to reinforce the frame structure, thereby not losing the rigidity of the engine bay.
Old 05-03-2010, 08:48 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
OK guys....too much talk not enough walk. Saddest thing is this is probably the most active thread on the network. Your header comment about splicing an extra set of stock WRX headers is what finally tipped me in that you have no idea what you are doing. If your lucky your cars will drive when you are done. If your really lucky they will pull to red line without falling on their face. A broken clock is still right twice a day.
icingdeath88: As far as a turbo goes for a low boost setup, I would still go with the 70 a/r 60-1 with 82 t3 hot side and stage 3 turbine. Feel free to email if you want advice. ECUTune aggressive works great for me, especially for the price. Need to be sure the header is the goods, otherwise your whole effort will be for not.
~Phil
Old 05-03-2010, 10:01 PM
superru superru is offline
just trying to fix it!
I guess you just woke up and all of the sudden knew everything to do on the EG33 right? what i feel like doing might not work, who the hell knows.. it's all trial and error, if your system is so fantastic then get the thing on the open market. if i'm lucky my car might start up after 300hrs of work, or blow up. i don't care. bouncing ideas off everyone seems to be great if i get good input and not basicily "your an idiot so have fun" i have nothing to do on this project until july so i'm kind of just thinking aloud and hoping for some good contructive input here.
uhh ya it's a subaru
Old 05-04-2010, 03:05 AM
Banned
Angry Re: building engines and turboing 2 svx's woot woot!
I've been researching turboing my svx for years now. I don't agree with his comment about the headers, however I do agree that putting this up for discussion before just hacking away ay my svx and praying it will work is in my opinion a much better solution. Yes we are doing lots of talking, but we both also work full time and aren't old and have pockets deep enough to fork out whatever cash is needed to **** up a few times before getting it right.
I have been studying both your setup as well as svxtasy's and I'm pulling ideas from both as well as my own ideas. I also don't want to just turbo it and see what happens. I plan to build the motor correctly with the internals that will be able to withstand the power I want. I also want to make sure my engine is not running to lean or too rich. I want to make sure that I don't buy 5 turbos before finding one that does the job right. I'm not trying to bash you phil but I plan to go with quality and make the fastest svx in the world, one that could potentially be a 10 second car.
So in order to save myself from being hassled anymore I will tell you to read the begining of the thread once more as it will state right there that we had no intensions of starting this project even as early as we are.
As far as an update goes I will say that before I can start tearing into my svx and rebuilding the motor I need to fix the front end from the wreck I was in last month. So I am working on my svx just not quite working on the turbo. And engine build yet, however cole and I plan to start hacking into. A parts svx here in the next few weeks and start test fitting some pipes.
Old 05-06-2010, 05:15 PM
Thanks for the input. How would I go about finding a turbo like that?
Old 05-06-2010, 07:41 PM
Phast SVX's Avatar
http://www.phoenixturbo.com
go to garrett turbochargers
Garrett T3/60-1 w/ .82 a/r
~Phil
Old 05-06-2010, 07:49 PM
he is right about the header... The merge needs to be as close as possible to the turbo and the wastegate if using an external needs to be on the merge for proper balance of the two bank pressures... Its not rocket science and I know Phil is being a little blunt... Sometimes you need to look at negative feedback with an open mind
Old 05-06-2010, 10:38 PM
Yes Phil is right about the header.
The basis of it is that the energy to drive the turbine, is the heat energy in the exhaust gas. So the closer that you can get the turbine to the exhaust port, the higher energy put into the turbine. So long single header pipes would dissipate a lot of that energy.
The problem is using a single turbo, as to do that, you have to separate the two banks exhaust ports, to prevent exhaust pressure interference. Thats why most six cylinders use twin turbos, to keep the exhausts short, keep the heat up, and no interference.
The header on that kit is too short a path from the two banks, it will cause interference as the pressure goes up. The one Phil has is the best to suit where the turbo is mounted, though for maximum, the pipe could be wrapped or shielded.
Old 05-06-2010, 11:00 PM
So, your telling me the WRX header design won't work not because i can't physically build one, but because of the individual tubes will cause an energy drop that will not be as efficient as as 2 pipe merge system..
well now that i understand, i was under the impression that you wanted all the cylinders to be about equal distance from the turbine inlet, that is why i figure using a "equal length" design would of been superior.. but now i understand..
Old 05-06-2010, 11:40 PM
Banned
my idea was to run the three on either side back similarly to the way they are originally but to sort of elongate it a bit and draw them to the center under the oil pan and y pipe into one pipe that runs over and into the turbo for the up-pipe. that way the header section is equal length but collects and goes up as the up pipe, reducing the right angles that need to be used increasing flow and reducing resistance.
Old 05-07-2010, 07:56 PM
Phast SVX's Avatar
I have mine wrapped up well in heat wrap from turbo to headers. I may not have done so if I drove my car a lot in rain and snow. even though you would most likely be using TIG'd 304L, the welds can crack.
~Phil
Old 05-07-2010, 08:29 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
here you go.....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-08-2010, 11:35 PM
Is this an O2 sensor on only one side?
Old 05-09-2010, 02:06 AM
Banned
Originally Posted by SVXRide View Post
here you go.....
-Bill
As I've stated before I plan to do a similar design to this just more streamlined and less right angles and drastic flow angle changes to allow for the path of least resistance to be easier.
