Old 05-26-2005, 02:43 PM
Rotorflyr's Avatar
Talking Tires, Tires, Tires
So what kinda of tires are you currently using on your SVX and what pressure do you run them at???
2006 B9 Tribeca
Old 05-26-2005, 02:52 PM
dcarrb dcarrb is offline
Bridgestone Potenzas on stock rims, about 38 front/34 rear. (I think spec is 33/29.) They were on the car when I bought it 22,000+ miles ago, and they ride well and are holding up fine. Not crazy about traction in the wet, though, so I might ask around for recommendations when the time comes to buy more.
dcb
Old 05-26-2005, 02:58 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Summer:
Falken Azenis ST-115 225/45-17 44 front, 40 rear.
Winter:
Hankook W404 Winter Radials (Studdable, but no studs) 205/55-16 on stock wheels. Could care less what the pressures are. When I check/refill I set them to 35 front 32 rear.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-26-2005, 03:05 PM
I posted mine here:
http://www.subaru-svx.net/forum/showthread.php?t=23837
I think I run 40/36
Old 05-26-2005, 03:08 PM
Hancook 245/45/16s on Di's, Nick's and Dave's, and Hancook 225/45/17s on my Claret.
Double A traction, fairly quiet, and OK wear. In the spring/summer/fall
but ,,,
snow traction is minimal on the 16s, and nonexistant on the 17s
Old 05-26-2005, 06:28 PM
lee lee is offline
BF Goodrich Traction T/A, 225X50X16, V-rated, 42 PSI in front, forget the rear, but it's whatever makes the loaded radius the same size (I think about 32).
Good ratings at Tire Rack and tread looks pretty good with about 10K miles on them, much quieter than the Fulda tires they replaced, no snow here, but unable to spin them in the rain.
Old 05-26-2005, 08:43 PM
I can spin them,
In the dry!!!
Old 05-26-2005, 09:10 PM
n00b on demand's Avatar
I'm running all season sumitomo tires. I'm also using 33 PSI in the front and 29 in the back as recommended. Is it bad to go above the recomended PSI ratings?
Old 05-26-2005, 09:19 PM
It depends on what you are doing with your ride,,, Higher pressures give you more controlled slide, less rolling resistance, quicker input, and some times, less traction...
Old 05-26-2005, 10:27 PM
1992SVX 1992SVX is offline
i have yokohama AS430 36psi front 32 psi back
overall good tires
Old 05-27-2005, 07:18 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I use Avid V4's and they stink in wet/snowy conditions
I need to get new tires because they give me very little confidence during rain driving all I do is slide if I brake too hard and there's plenty of tread left.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-29-2005, 07:01 AM
JonathanS JonathanS is offline
Thumbs up
Hankook Ecsta ASX on the stock wheels and spec pressure. Great reviews on Tire Rack, and I'm satisfied. Great price, too.
Old 05-29-2005, 09:23 AM
thundering02's Avatar
Giong back to the beaters...
Stock sizes with potenzea RE950's 3 v speed rated one t speed(only 4k miles difference) cause I had a flat and the particular exact model was being discontinued
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 05-29-2005, 11:11 AM
Mr. Pockets's Avatar
Moderator
Dunlop D60/A2 JLB. I use the factory-recommended pressures on the door frame.
This is my second set. I've been thrilled with them, but Dunlop has, of course, discontinued the tire.
I'll probably try something from Sumitomo next. I had Sumitomo HTR-200s on my Justy and they were fantastic tires. They even held up well after a year of autocrossing on them.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 05-29-2005, 12:46 PM
Rotorflyr's Avatar
You mean Kumho Ecsta right??
I currently have Sumitomo's HTR+'s on stock rims @ stock pressure they are starting to get worn, and don't much care for the ride you get with them (although grip is good),I will most likely go with Avon M550's from TireRack on the American Racing rims I bought from sxewhodey, and then probably put snow tires on the stockers.
2006 B9 Tribeca
