245/45-16 or 255/45-16
Anybody got pics of theirs? I know about the 255's rubbing btw.
Re: 245/45-16 or 255/45-16
On stock wheels? I run 245/40/17's on my BBS rims with tons of room to spare.
Yes, on stock rims.
Why do you want to run such a wide tire on 7.5" rims? You may have a higher ultimate grip, but the way the sidewalls will be pulled in will result in some nice wallowy handling. You're far better off to just run a sticky set of 225/50/16's.
Edit: In fact, now that I looked Tire Rack doesn't show any tires in 255/45/16, and few in the 245 width. 245's look to be approved for 7.5-9" rim widths, with the ideal being 8-8.5.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 05-28-2010 at 08:53 PM. |
ok, last thing I want is to make the car handle worse. I was hoping the 45 aspect ratio would yeild a more attractive/stiffer sidewall. Extra width is appealing too. It seems to me +17" (aka shorter sidewall) rims have a far better looking, beefier sidewall, but I want to keep the stock rims. Perhaps because I haven't been researching the right brand/price range tires, they mine look pretty nasty. Like a balloon! I'm not sure what they look like in a 225/50-16 but I found these interesting.
http://www.tirerack.com/tires/tires....omCompare1=yes and these http://www.tirerack.com/tires/tires....omCompare1=yes Prime example of ugly sidewalls: http://www.tirerack.com/tires/BigPic...omCompare1=yes
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 05-29-2010 at 10:01 AM. |
Well the thing is that the sidewall number is relative to the width of the tire. It is actually a percentage of the tire's width (ie: a 50 profile tire has a sidewall which is 50% of the tire's width). If you maintain the rim size and overall tire diameter you aren't actually changing the sidewall size at all. Going from a 205/55/16 to a 245/45/16 will get you a wider tire with the exact same sidewall size.
My 2 cents is that a jump from 16 to 17" wheels yields the biggest bump in handling, while not hiking the cost too much (going to 18" makes things nasty). I run 205/55/16 Blizzaks on my stockers in the winter and always love the improvement in control I get as soon as the summers go back on. I agree the Pirelli's you have pictured are ugly looking. The Hankooks are said to be quite good. Those Yoko Advans are not what you want. They're a competition tire meant more for auto-x/track use. They'll be awesome tires, but burn out real quick.
I agree the jump to 17 or 18 would cure my problems, but I'm trying to keep cost down and more importantly keep the stock rims. This is why I'm looking for a decent pic of a 45 profile tire in the class of tire I gave the links to. It may not be a whole lot different but the construction may be different. I don't know much about tire anatomy but I'd like to find a more pronounced curve/thickness in sidewall right where the rim meets the tire.
As far as wear goes, my SVX only sees under a thousand miles each year all sunny days.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 05-29-2010 at 11:25 AM. |
I have a question about some of my tires. I have some 225/50-16 snow tires for my '92 which is the size the car calls for. Will I be able to use them on my '97 which calls for the 215/55-16 size? Does anyone know why they changed the size of the tires for the '97?
Thanks
Dave 1997 Laguna Pearl LSi 39 000 mi 62 000 km 1992 Claret LS-L Sold 105 000 mi 169 000 km 1988 XT6 Written Off 111 000 mi 180 000 km |
IIRC the change in size was only to help fuel economy & production costs.
That's my conclusion, both are relevant factors, especially the economy . 600-plus production couldn't have saved much cost though
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
