Old 06-26-2012, 08:08 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Changing fluids
I'm up for an oil change.
Should any other fluids be replaced at the same time? I know AT oil was replaced in december, brake fluid some weeks ago (I assume they changed or checked when they replaced the brakes), but how about differential oil?
Any recommendations for grades/ products I should use for the various reservoirs?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 06-26-2012, 08:22 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: Changing fluids
See my signature line.
Tony
Old 06-26-2012, 08:32 AM
jetboy's Avatar
Re: Changing fluids
Yes sir! Any suggestion on differential oil?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 06-26-2012, 10:26 AM
Re: Changing fluids
The gear oil goes in the front and rear differentials.
Tony
Old 06-26-2012, 02:44 PM
Re: Changing fluids
Tony, what do you think about AmsOil DOT4 brake fluid?
I believe that I am going to put it in the cars I care about.
Old 06-26-2012, 03:49 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Changing fluids
I am not a fan in flushing the ATF. Both times it was done on my SVX, my Trans failed. Coincidence?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-26-2012, 05:01 PM
Re: Changing fluids
I haven't looked into brake fluid much. Amsoil makes decent stuff like Mobil 1 does and BG does. With brake fluid, I would think heat transfer and heat capacity would be the most important along with coefficient of expansion and water solubility. I just don't know how the good guys stack up against each other in brake fluids. The first place I would go to research it is bobistheoilguy.com. They even have a decent search engine. I would bet Amsoil, Redline and like minded companies would all have good products.
Tony
Old 06-26-2012, 10:00 AM
Re: Changing fluids
I know the AT oil was replaced in December, brake fluid some weeks ago (I assume they changed or checked when they replaced the brakes)
Don't assume they changed the fluid and flushed the entire system and replaced it with new fluid. They may have just replaced the worn pads and topped off the system at the reservoir.
If they replaced a brake caliper, they would have bled and flushed the system. Check your receipt or ask the shop.
Brake fluid should be changed about every 2 years. If you are not sure when it was done, it's better to replace it.
