checking codes
Wondering if someone can help.I recently got a cel and following the how to to check codes, I took off the cover, found the 2 blue wires but the black connector doesn't have a wire to the 2nd hole on top left side it has an orange wire in the first socket.I also found tucked under the carpet a female connector that would mate to the other. This one has a foam cover on it and only has one wire to it(black).Should I be tapping the orange wire for code and should these be reconnected when done? Anyone run into this before? the car is a 96 lsi I can't tell what color wire goes to the 2nd socket from the photos
Re: checking codes (wires don't match instructions)
I am exactly where you are, did you ever find an answer?
The black box has no contact in the second-from the left opening. There *is* a separate wire taped up with a female connector on it, but if I stick the blue wire in that all that happens is that the right "door-open" connect goes on. See the attached picture. Thanks! |
Re: checking codes
I don't know which file you looked at, but if you click here, you will see you have everything you need to check the codes. If you have already seen it, read it again. Good luck.
Re: checking codes
Since both of you are trying to check codes on 1996 OBDII cars, why are you not using a code reader to plug into the diagnostic connector to the right of the steering wheel?
OBDII Code readers are inexpensive and allow you to clear the codes as well. .
Re: checking codes
Up until now I've had very few reasons to want one, but given the age of the car, I guess it's time I got one. Unfortunately right now I'm 200 miles from home. Hopefully whatever is wrong will wait until I get back. Thanks. |
Re: checking codes
I didn't know that you both had 96s. That would have helped a lot.
Re: checking codes
This is the same location that was occupied by the coin holder in the earlier OBDI cars (1992-1995) .
