Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 08-04-2006, 01:45 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Cool BillStock v3.5 gets seats
Corbeau race seats, recovered to match
Only 24.5# each...5 point harnesses sitting in the living room
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-04-2006, 01:51 PM
Pretty...
You better keep them away from brick walls...
Old 08-04-2006, 02:19 PM
Not bad lookin'.
Not comfortable looking, but it's not bad looking.
Old 08-04-2006, 05:52 PM
Subafreak's Avatar
Superbeast
Bill do you make womans dresses in your basment at night?
BTW: nice job on the seats.
Old 08-04-2006, 08:52 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Those seats look amazing Bill! Next season when I'm on r-comps, I hope to make it up to a few events with the WDCR SCCA, I'll definitely need to catch a ride with you on one of your early runs.
Question, can you change the trans in ESP? A nice 5/6MT would really help you close the gap on those Camaros!
LOL!!!!
Chike
2006 Steel Gray WRX TR (sold)
Old 08-05-2006, 08:44 AM
sicksubie's Avatar
How hard will the install be? What rails are you going to be using?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-05-2006, 12:48 PM
shotgunslade's Avatar
Bill:
How are you mounting the 5 point harnesses? Do you have a roll cage installed, or, hopefully, you have a removable harness bar, so I can get the product information and copy you.
Dan
Old 08-05-2006, 01:39 PM
SVXRide's Avatar
Jesse,
Nope, took the pictures at the shop that did the work - owner works out of her basement. She splits her work between custom car interiors and uphostery on high end boats.
-Bill
Old 08-05-2006, 01:45 PM
SVXRide's Avatar
LOL!!!!
Chike
Chike,
No problem. Interestingly enough, I was reading back through the ESP rules yesterday and swaping in a 5/6MT isn't allowed, as the SVX never came with a MT. Adding a s/c is also not allowed. Good thing is that I can modify the body for any clearance I'll need for the 275s
-Bill
Old 08-05-2006, 01:52 PM
SVXRide's Avatar
Originally Posted by shotgunslade
Bill:
Dan
Dan,
I'm going to spend some time in my machinist's shop this coming week and a harness bar is on the list. I'd like to install one just aft of the top of the rear seat so people can still sit in the back (you can't remove the rear seat in ESP)
-Bill
Old 08-05-2006, 01:54 PM
SVXRide's Avatar
SVXFiles supplied a pair of passenger-side rails that I'm going to modify to work with the seats (Thanks, Tom!). Jesse did the same when he installed the Sparco seats in his SVX.
-Bill
Old 08-07-2006, 12:18 PM
They certainly LOOK nice. How do they FEEL?
Bill, they look GREAT!!!
This is the first moment I've had in three days to look at them.
I can't wait to see them, and sit in them, in person.
How is entrance and egress?
Old 08-07-2006, 02:14 PM
SVXRide's Avatar
Tom,
Actually, pretty good. They definitely have more "give" than the seat in Ben/Dave's RaceCar. Still, probably not what I'd want to sit in for a cross country trip, but that's what the Pearlie and its stock seats is for
-Bill
Old 08-07-2006, 03:59 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by SVXRide
Tom,
-Bill
Watch it there hotdog (aka brick lover) I can sit in that race seat for at least 20 minutes without an issue provided the cabin temp is below 135 degrees.
Old 08-07-2006, 06:02 PM
mbtoloczko's Avatar
sans SVX
Nice looking seats. Have you gutted the interior yet?
Mychailo
Visit my locker
