Old 07-15-2009, 10:05 PM
Re: BAD NEWS! THE Svx took on the ditch and tree and lost
Looks bad, but after looking again, it may be repairable. Good luck.
Old 07-15-2009, 10:23 PM
PFFFT!
That will buff right out, and YT would be done by now!
I am not really trying to make light of this but I would fix it!
Old 07-15-2009, 11:07 PM
PFFFT!
Make light of it. You wont hurt my feelings! It is in fact my fault it looks like that! Ill take any advice or pointing in the right direction on where to find info on how to actually replace that glass. I.E. how to do it? I would imagine my best bet is to pull headliner, bang out whatever i can with a body hammer, and then see how the windows attach. It appears to be window caulk, and plastic knobs that push into receptors. I.e. door panel clips for lack of better example.
Old 07-16-2009, 02:23 AM
Need to ask you, what is the extent of damage to the front of the car? I am asking this because I can clearly see a part of your waterfall grille in the backseat place.
The hardest part to fix is your roof. The glass is easy to replace though...
The sides, the rear, is not that hard also... If I am not mistaken, the roof panel has weld pins all around, those weld pins can be heated again and you can remove it entirely and replace it with a new one. Again I might be mistaken (I've seen them on some cars...)
Good luck!
Old 07-16-2009, 05:01 AM
As for the glass, after you pick up the replacement glass, and have the roof channel back into shape, call a glass shop to have them install it, as I feel this is one area a professional should be used, to ensure you don't have leaks.
I can get a windshield installed for $50-$60 here, so I'd say you could have those 2 side glasses installed for about $100-$150 (plus the cost of the glass)
Old 07-16-2009, 07:50 AM
The front of the car sustained no damage as he car slid sideways trying to pull itself back up the embankment. The waterfall has been in the back for quite a while. The front of the car kissed a trailer hitch prob. 6 years ago at this point. If i could get away with just drilling the spot welds and popping a new roof on that would be sweet ! As far as the glass I will have to think long and hard about that when that time comes. I appreciate any help with how to's on removing the glass or headliner.
Old 07-16-2009, 09:31 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
The upper glasses are basically glued on the frame with windshield sealant, not that hard to replace but its going to be a pain when removing the broken ones.
I have all 4 upper glasses and rear windshield sitting in my garage and ready to be installed.
The junk yard I am talking about
http://www.subaru-svx.net/forum/show...t=30565&page=2
post # 29
http://www.subaru-svx.net/forum/showthread.php?t=50916
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 07-16-2009, 09:37 AM
pearlm30's Avatar
Check your PM.
Im in oldsmar off tampa road by the amc 20. What part of tampa are you from? That is awesome you have all the parts! Also awesome on the heads up in orlando. Is that the upull it by the college? Or atleast near that area?
Old 07-16-2009, 10:00 AM
post # 29
I wonder if Subaru sells that sealant, I like to have a couple kept aside just in case. And I know, I know.... I can get it aftermarket, but I like the same sh!t subaru uses in its cars.
Old 07-16-2009, 10:32 AM
Elliott's Avatar
Elliott Elliott is offline
Subaru probably just relabels 3M Window Weld and sells it at a marked up price.
Old 07-16-2009, 10:50 AM
Awesome! I appreciate all the info and help guys!
Pm replied to.
Thats good to hear they are just basically glued in. I am going to start and try and get the old glass out now and then pull the headliner to work on the window channel.
Old 07-16-2009, 11:27 AM
Don't forget there are 2 different "Factory Tint" colors...you want to get ones that match your other windows....
And use a razor knife to cut out the old glass....shouldn't be to bad since they are already broken
Old 08-24-2009, 10:53 AM
Ok so i have the rear window and the upper window for the rear pass. side, and I am trying to figure out the headliner or if its even worth pulling the headliner. I have it down on the pass side where i need it and its got a reinforcement bar that is in the way of the crease that needs to come out. Would you suggest getting one of those "stud welders" and then pull it out from the exterior of the vehicle? It looks like that might be the only way to do it. I am just asking for suggestions nothing in particular. Hopefully i will be able to save up the remaing couple hundred dollars and get the remaining glass and trunk. Thanks again for all the help with everything.
Old 08-24-2009, 03:09 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I would use a combo of the stud gun and a shrink hammer on the roof creases.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-24-2009, 03:18 PM
ok thanks for the suggestions ill look up the shrink hammer as i have never heard of that. Thanks again.
