Old 04-17-2014, 03:17 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Helix Throttle Body Spacer
Ive been selling and using the HELIX brand throttle body
spacers now for about 7 yrs and have never had 1 come back
with a customer not happy with using it,
Always better MPG and small hp gain, 4-7 hp
I put one on my Vehicross last yr and love it.
So now Im getting them made for the SVXs.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 04-17-2014, 05:49 PM
Re: Helix Throttle Body Spacer
Outlaw engineering seems to be defunct. Can this company make intake manifold spacers as well? Several people on the Facebook groups have been asking about them. They seem to be popular for eg33 modders, so there is a market for them.
Old 04-17-2014, 07:00 PM
theflystyle's Avatar
Link for the throttle body spacer
http://svx-motorsport-accessories.st...lvxthbosp.html
1994 SVX LSi
2008 Legacy 3.0R
Old 04-18-2014, 04:50 AM
yeah, no problem...
do someone have a pair to loan us so we can
possibly use to spec them out ?
If not, I can probably send them a pair of gaskets
to mock up some prototypes.
How thick ?
I have 2 sources that can do this for us
One will probably use billet aluminum, but the other will
actually use Phenolic material to limit heat transfer as
much as possible, this material is a smarter way to go.
Not sure what your originals where made out of.
The spacer should look something like this for the throttle body
and be about 1" thick when done...
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 04-18-2014, 06:03 AM
Tireiron Tireiron is offline
For the intake manifold, just use 1 gasket as a template, they are symmetrical. The old ones are phenolic, aluminum would defeat the purpose of the part. Most phenolic spacers I deal with are around 8mm thick.
Old 04-18-2014, 09:25 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Just a caution to throw in here. There is no way you'll be able to use a TB spacer as thick as the one in the photo unless you want to take a chunk out of the firewall for clearance.
Cheers,
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-18-2014, 10:34 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Cheers,
Bill
i was gonna say, how big can you even go on an svx? the intake is a pain enough to put on with that clearance
Old 04-18-2014, 11:43 AM
Here is a picture of the Outlaw spacers... Times like these make me wish I had a 3D printer. I could make a negative and cast these bad boys.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-18-2014, 01:36 PM
Cheers,
Bill
My thoughts exactly!
Old 04-20-2014, 07:32 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
I have a set of the Outlaw spacers on my engine, and I still have a problem getting the snorkel on and off with the 1/4" reduced clearance.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 04-22-2014, 02:44 PM
I think theres enough room
Once the prototype is done Im going to test fit it on one
of our cars and take it from there..Nothing would ever get
done if we had the cant do attitude all the time
We like a good challenge anyways
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 04-22-2014, 10:27 PM
SVXRide's Avatar
note that I didn't say you couldn't do it, only that you're going to have to take a chunk out of the firewall to make it fit.
the alternatives are fabricating a new snorkus that is shallower or flipping the intake so the TB is up by the alternator...
good luck
Bill
Old 04-23-2014, 04:14 PM
what is the thickness exactly in metric or std
we need the spacers made for the manifolds ?
and we only need one pattern right ? because they
are a mirror image of each other ? or am I wrong..
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 04-23-2014, 05:47 PM
You are correct, they are symmetrical side to side. The important one is between the heads and the intake manifold. Around an 8mm phenolic spacer should sit about right. The one between the upper and lower manifold doesn't matter if you keep the heat separated from the heads to the lower manifold. The intake manifold gasket from Subaru is almost dead on, I've never felt the need to port match a Subaru intake because of how close everything lines up.
Old 04-23-2014, 06:11 PM
so then we just want the 2 pcs from man to man, correct, 8mm is ok
thx, I have a guy who can make me the 2 pcs manifold
to manifold units, but we have to buy a min of 70 the
way it looks, which would do 35 cars.
No pricing yet.
Are people sourcing out there own gaskets from their
local dealer and bolts from the hardware store ?
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
