Old 09-21-2005, 02:08 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Question main&rod bearings
how hard is it to replace the main and rod bearings? it looks like it could be done with the engine in the car. the knock i've had when cold is sounding louder and i'm really thinking i need to do the bearings. anyone know a place to get a good price on them?
Old 09-21-2005, 05:33 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The engine has to be removed and completely disassembled and the case split to replace the bearings, not a job for the faint of heart.
Old 09-21-2005, 05:56 AM
GreenMarine's Avatar
From POST-***** to LURKER
I was gonna say on a scale of 1 - 5.... You're looking at about a 5.... That's probably almost as hard as it is gonna get... taking the engine out, splitting it open, replacing the bearings and putting it all back together again so that it will run again... Definitly possible.... But with the engine open, you will need to take certian precautions so as to not damage any of the internals...
Old 09-21-2005, 10:57 AM
Budfreak's Avatar
Banned
well, i guess i just drive her till she dies then. i can't possibly afford to get it fixed and i have nowhere and no time to do it myself. i'll just worry about my pulley and keep the oil change but i'm pretty sure it's a bearing going bad so my time as an svx owner may be limited now.
Old 09-21-2005, 11:04 AM
dcarrb dcarrb is offline
Be on the lookout for a low-mileage, salvage engine. My guess is a transplant would cost considerably less than a teardown/overhaul. You could keep the old motor and work on it as time and funds become available.
You're sure you're not just hearing that lopsided crank pulley hitting the timing belt cover?
dcb
Old 09-21-2005, 11:11 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
dcb
Ah throw some valve medic in it and turn up the radio. Oh yeah when the old is out send it to Dave and I and it'll get rebuilt into a NA 300hp engine that you can brag to your friends about (granted it'll be in our race car then) .
Old 09-21-2005, 11:13 AM
Budfreak's Avatar
Banned
dcb
yes i'm pretty sure. i was laying underneath it yesterday and could hear it pretty good. from the top of the engine it sounds like the knock is in the back of the engine. i figure that pulley being like that has probally put alot of stress on the back bearings and there failing. i'm searching for a pulley now although i can't afford one for 3 more weeks.
BTW, the knock goes away or just gets really quiet as i think i detect it every now and again when it's warmed up all the way and been driving a few miles.
Old 09-21-2005, 11:21 AM
What pulley are you looking for, AND are you sure it's not a cracked flywheel?
Old 09-21-2005, 11:24 AM
Budfreak's Avatar
Banned
no i haven't had a chance to check the flywheel but i will as soon as possible. i need a crank pulley.
Old 09-21-2005, 11:31 AM
Do you want stock, or underdrive?
If you think you are having crankshaft issues, I'd stick with a stock vibration dampener.
Old 09-21-2005, 11:35 AM
Budfreak's Avatar
Banned
i'd prefer underdrive. how much do you want for either one?
Old 09-21-2005, 02:20 PM
Budfreak's Avatar
Banned
took care of the whole pulley thing.(thanks tom!) i'm gonna check my torque converter bolts and make sure there tight and if they are then the problem will have to continue till something shows it's ugly head i'm gonna try a heavier oil when i change it next and see what happens too. any other suggestions are welcome. thanks
Old 09-21-2005, 03:43 PM
Beav's Avatar
Not as old as Randy
Cracked flexplates are more common than bad bearings. Main bearings sound like a thud and rod bearings usually make noise around 1500-2000 rpm and slightly decellerating. Rods are a kind of rapping noise, flexplates clatter at idle or just above, generally.
Old 09-21-2005, 07:13 PM
Budfreak's Avatar
Banned
yes, i discussed this with svxfiles and i have no way to move that tranny to check but i will check the torque converter bolts.i'm not to terribly worried since it's done it since i got it but i'd still like to figure out what it is so i know whether i'm facing impending doom or not.i won't complain a whole lot if the flexplate breaks but i'll cry like a little girl if it throws a rod threw the block it makes the most noticable noise when started cold and the idle hits 1250. then the noise begins and it does it till warmed up.i'm also thinking my knock sensors are picking it up cause it has no power at all till it gets warmed up and the noise goes away then it's pretty much zoooommmm! business as usual(except for some stinky pre cats). the pre cats will go away in a few weeks when i bypass them with some adapters and pipes from advanceauto.
Old 09-21-2005, 09:07 PM
Beav's Avatar
Not as old as Randy
Are you sure the oil isn't overfull? It is a boxer engine, you know. (A pat on the back to those that understand how that would come into play here.)
p.s. Mine also thunks a bit when cold. Just let it warm up a bit.
