#1651
Re: SVX Engine cooling "Again & Again"
Yea I got that but overall it seemed like you misread.
#1652
I found the solution. I sold my EG33 powered Legacy and bought a 911 Carrera
Seriously though, this is fascinating stuff. Keep it up. I'm still reading it as you can see. |
#1653
A substantial increase in bypass flow capacity might not be a bad idea to try. Maybe controlled by a solenoid valve - open above 4500 rpm? Might not be that difficult to arrange. There are big plugs in the lower surface of the block. The pump inlet can be drilled for the fittings. Eh? T
#1654
Good idea ! But ain't that open until 2500 rpm, then closed, and opened again at 4500 rpm or so?
/T |
#1656
Bazza, have you seen this product?
http://www.ebay.com/itm/350590711709 This is also interesting. ECU controlled electric thermostat http://prodcds.bmwuniversity.com/lib...2%20Engine.pdf The intelligent heat management including better efficiency with high engine temperatures is explained. There's also the DISA intake system, very nice and works the same as ours ! Tapani Last edited by Tapani; 10-04-2013 at 11:40 AM. |
#1657
Further on map thermostats and other stuff:
http://www.behrthermottronik.de/file...thermostat.pdfElectrically heated and electrically actuated thermostats http://www.wahler.de/fileadmin/wahle...schuere_en.pdfCheck out the two port valve here.... could be used to control an extra bypass circuit per engine speed. http://www.thermotion.com/topic/18-e...rol-valve.aspx/T Last edited by Tapani; 10-05-2013 at 06:41 AM. |
#1658
This has been touched on before, but has anyone tried the Evans waterless coolant?
It's supposed to be superior to glycol/water against cavitation - see here: http://www.evanscoolants.co.uk/techn...-no-erosion/47 I know cavitation in large diesel engine cooling systems cause cylinder liner erosion problems - I've seen it many times. Here's a test result from SwRI (used to work there a long time ago ) http://www.evanscooling.com/assets/U...n-Results2.pdf The liner erosion caused by cavitation was significantly reduced compared to the reference coolant. I know the heat transfer is somewhat less than standard coolants, but if that is not the limiting factor.... someone who actually has this problem might want to try, eh ? /T |
#1659
Seems to me that it would be worth a try. Maybe the combo of reducing the wp efficiency, plus the waterless coolant would give a decent compromise of high enough flow at low rpms to keep things cool and low enough flow at high rpms to prevent cavitation. I'm still liking the electric water pump route more myself, but Evans/drilling wp could be a lower cost alternative that gets the job done. Out of curiosity, is the waterless coolant usually allowed by competition rules?
#1660
What do you guys think - should we try to describe how the SVX cooling system works? And how different issues affect the system with a holistic perspective?
Please feel free to argue, correct, add and comment :-).... my sole purpose is to get an agreement on the basics. This is just free flow of thoughts.... not a comprehensive description nor written in the most logical sequence.
#1661
Tony,
When I tried to respond to your PM, the Network's system says you're not taking messages. Would you mind sending me a PM with an email addy I could contact you through? Cheers, Bill
#1662
Tapani - I've not replied as that hurts me head every time I read it haha
#1663
And you're the one who makes the most mods yeehaa !
#1664
So bit of an update.
A bit of background - my mate has the 1000 bhp EG33. However he is testing the cooling systems and electronics with a stock EJ207 which is making about 450 bhp. The cooling system is using an 150L/min electric water pump to suck water from the radiator to the engine and another to suck water from the turbo / oil cooler and return into system post motor. The AMAZING thing is it's works extremely well. We've been doing some track events and he is sitting at 80-85'C each session (and he is not far off lap record pace) whereas with mine (I'm also running a stock EJ207 at the moment) it tends to get a bit hot and up to 100-105'C (although I'm running my stock EJ207 up around 475 bhp and using a stock STI radiator behind a FMIC.. duh!!) I am testing a bigger radiator next weekend on mine then I'll be gutting the pump and running an electric water pump. Later we'll be testing the 1000 bhp EG33 engine with the electric water pump. Seems Tony and Harvey were very wrong about a lot of things. |
#1665
Good to hear from you !
Keep us informed - it would be nice to get to the bottom of all this. /T |
