i need a tranny
my transmission just died and i am looking for a used one so it will last a little while until i save up some money to get a new one so if any one could help me that would great thx.
A good used SVX trans will run you around $750-$1,000. A rebuilt or new SVX trans will be $2,500+.
Are you going to do the work yourself or have a shop do it for you? If you can do it yourself, then I'd recommend buying a used 4.11/4.44 trans from a '93-'98 Impreza or Legacy and swapping that and the rear diff into your car. These parts in total will run you about $400-$500 as junk yards have these Subaru models in abundance. The shorter gearing will raise your revs in each gear, thereby multiplying the torque transmitted to the wheels and making your car even faster. The gearing will also reduce the strain placed on the trans as the gears will be doing more work. The swap is reasonably straight-forward and a direct plug-n-play for your SVX TCU. Do a search under 4.11 or 4.44 for more info. Svxfiles, myself, boxer6, SVX-FF all have modifed gearing in our cars and SVX-FF has a write-up in his locker. Just an option to consider... -Chike
tranny
i just want a used one for now cuz i am driving my little brothers 84 GL and it's not a ladies car and i will save up some money for a little while and my dad works for subaru and he can get me a brand new one for like 1500 after we give them my old one and then with the extra one we will rebuild it so when that one goes we wil put this one in it. my dad and me r gonna put the tranny in ourselfs not that hard so....
for $1500 from Subaru tell him to order 2, and Ill take one
I may have to make a trip to georga. at the rate my trans is going.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
Sold-Black 97: They're All We'll Drive-into the side of a Pathfinder that lost it's path! 2004 Stage 3 XT Forester-Soon for sale! 2007 Jag S-type, just 17k on it! Past prides: 1992 black LsL new off the lot. 1992 pearlie for a few months. |
Chike is saying buy an Imprezza or Legacy automatic (same box), and a Legacy rear differential (has to be swapped as the gears are a different ratio) - make sure the two match in gear ratios - should be 4.11.
In my experience, getting a good used box is much cheaper. I paid $1600 for rebuilding a unit a couple of years ago (I pulled and replaced the box myself - this was just for the rebuild). About a month or so ago I paid $850 for a used 1998 transaxle and rear differential that had only 29K miles on it and had whatever internal system improvements Subaru had made on the 4EAT between 92 and 98. Last, I don't see a rebuilt price being significantly different between the SVX and Legacy/Imprezza. The cheap part comes because you get a used one from a wrecking yard and there are many more wrecked Imprezza/Legacys than SVXs. |
Comprendo, are there diferent ratios between Legacy boxes that need calculating for the new rear gears? and do you need to change ring/pinion to match the box or just find a set that'll end up at 4:11?
All I can speak to with authority is what I have - a 98 Imprezza auto transaxle and a 97 Legacy rear differential (from a manual shift Legacy). The rear diff ratio must match whatever transaxle ratio is picked. 4.44 is also an option depending on price & local availability. A grinder (for the rear diff) a good assortment of hand tools, a couple of jackstands and a day or two and the swap can be done in a home garage - at least that's where I did mine. |
it isn't my trans it is my fron differential i need a new hyploid gear and the shaft so thanks for the help everyone
What I'll add is this: You have three different gearings at your disposal to choose from - 3.90 gears from turbo Legacys with a 4EAT 4.11 gears from NA Legacy sedans and wagons, and Impreza sedans as well as the Impreza Outback Sport Wagon. 4.44 gears from the Legacy Outback wagon The Impreza rear diffs are very small and aren't large enough to swap in the limited slip from your SVX rear diff. Therefore, if you get a 4.11 Impreza trans, you'll need a 4.11 rear diff from a Legacy sedan or wagon. -Chike
What's our stock final drive ratio?
All SVXs that were sold in Europe, Japan and Australia have 3.70 gears. -Chike
No wonder it's a slug off the line...!
