Old 01-13-2013, 11:42 AM
shark_22 shark_22 is offline
High compression information
Hi,I'm building my eg33 high compression for next summer, Im using sti rod and the eg stock piston.
But I need help to choose the good gasket thickness and how many mm I have to shave on the head,
Finally, I want to regrind my camshaft but not sure of the spec
hope you can help me
thanks
Old 01-13-2013, 07:29 PM
bishop bishop is offline
Re: High compression information
Cosmetic makes Headgaskets for the eg and ecutune has cams for the engine.
Old 01-14-2013, 05:52 AM
Cometic The question is size not supplier.
Old 01-14-2013, 01:40 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
+1
I've been wondering the same info as well. I believe smc used thinner head gaskets to achieve 11.5:1 compression.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 01-14-2013, 02:34 PM
The stock thickness for the Cometic head gasket for the SVX is .066"
Bore is 98mm (stock), 100mm, 102 mm
The center or shim layer is uncoated stainless steel layer which can be adjusted to accommodate multiple thickness requirements. This is in case of excessive head or block resurfacing to restore the original specs and compression ratios. You can have the MLS (multi-layer steel) gaskets made in the following thicknesses:
.027", .030", .036", .040", .045", .051", .056", .060", .066", .070", .075", .080”, .086”, .089", .092”, .095" .098”, .120" and .140"
http://www.shopengineparts.com/produ...3L&type=engine
Old 01-14-2013, 06:39 PM
http://www.subaru-svx.net/forum/showthread.php?t=58062
Have a look at this thread.
Old 01-15-2013, 06:43 PM
yeah, bore 98mm, but what can be the best thickness
I know smc use 0,040 one
In additional of this, I have to found how much I can shave the head to increase the compression
Old 01-15-2013, 08:28 PM
It's difficult to calculate that, since when you shave the head you change the shape of the combustion chamber a bit. I would talk first to the machine shop you think will do the work and see what they say.
Old 01-21-2013, 11:24 PM
Dessertrunner's Avatar
Also keep in mind that shaving heads will alter the cam timing due to the belt changing its length from crank to cam. I posted a spread sheet were I did a rough and dirty calc on what shave will give what compression increas and how much the timing will change on each bank. I can't remember were I posted it but some one might know.
Tony
Old 01-22-2013, 01:20 PM
http://www.subaru-svx.net/forum/showthread.php?t=59845 (see post number 40, but also read on.)
