Old 05-30-2012, 04:13 PM
bazza bazza is offline
Re: Increasing Compression
Originally Posted by Dessertrunner View Post
Two questions
If shaving the head is the way to go how much needs to be shave to increase it to 14:1.
Does any one know were to get the piston if thats the way to go.
Harvey the higher compression is for the race car.
Tony
Sps pistons in melbs
Cp in USA
Will do whatever you wish after you send em your stock piston for base. $$$$ though
Old 05-30-2012, 05:38 PM
Cp in USA
CP pistons doesn't need a base any more, they have done enough EG33 pistons by now.
Old 05-30-2012, 06:16 PM
Indeed, however you only get sub 10:1 compression pistons for their on file designs.
Old 05-30-2012, 07:11 PM
Dessertrunner's Avatar
baza,
You may not know but I am building a engine dyno so at the end of the day it will be easier for me to shave the head and that way I can play around with different compression ratios.
So guys how much do I need to shave off?
Tony
Old 05-30-2012, 07:20 PM
baza,
Tony
What a top idea. Have you got a thread detailing this build, I'd be very interested
Old 05-30-2012, 07:59 PM
baza,
Tony
Tony you need to remove 18.5cc from the clearence volume.
Removing the 0.060" head geaket will only drop it 1.87cc.
Last edited by oab_au; 05-30-2012 at 11:40 PM. Reason: If I didn't fix the metric/Imperial fault. Tom would.
here,
http://www.subaru-svx.net/forum/showthread.php?t=54640
I have been as "flat out as a lizard drinking" over the last year but plan to get back to it soon. I have worked out soluations in my head.
Tony
Old 06-01-2012, 04:09 PM
Okay some rough numbers.
3,318 Litre
6 Cyclinder
97 mm Bore
7.3928 Area of piston
Target compression Final Volume Difference MM to Shave
Current 10 55
11 50 5 0.680
12 46 9 1.247
13 43 13 1.726
14 40 16 2.137
15 37 18 2.493
I think there maybe mistakes so if so please yell.
Tony
Old 06-02-2012, 12:41 AM
Here is some more info,
It might make more sense in the JPG.
Spoke to the guys with the cam pullies and they allow plus & minus 12degree adjustment. According to my calcs if you were to run 15:1 the left bank would need 7.8 degree of adjustment.
Okay were am I at.
Shave heads is the only way to go because I have a lot of heads and I can experment with different compression ratio with little effort. I can just put them in my cnc mill and plan them off. The pullies will enable adjustments simply.
Have a great day all.
Tony
Old 06-02-2012, 12:55 AM
detail of calcs
Old 06-02-2012, 07:54 PM
3,318 Litre
6 Cyclinder
97 mm Bore
Current 10 55
11 50 5 0.680
12 46 9 1.247
13 43 13 1.726
14 40 16 2.137
15 37 18 2.493
Tony
Tony yes there is a problem with those numbers. You are assuming that the combustion chamber is a cylinder, so that each 0.5mm shaved will result in a reduction of 3.7cc, but the chamber is not round, it is a flat sided oval, so the cut of 0.5mm of the chamber, won’t yield 3.7cc, it will be a lot less.
You would need to cc the chamber to see what volume that shaved 0.5mm would be.
Old 06-02-2012, 08:21 PM
Good point Harvey you are right.
Do you agree with the basic Logic on timing adjustment or did I get that wrong.
Old 06-02-2012, 09:05 PM
Yes that is the way the timing will change. Looking at the timing belt, if it is all set to the marks, and the heads are moved in towards the crank, the adjuster will pull the belt slack down, rotating both pulleys anticlockwise, the right will move twice as far.
Old 06-19-2012, 08:57 PM
dynomatt dynomatt is offline
Admittedly it has direct injection, which allows a higher compression ratio, but the latest Subaru BRZ/Toyota 86 has a boxer Subaru engine with 12.5:1 compression. Might be a target for you Tony? Or are you already past 12.5?
Old 06-19-2012, 09:55 PM
I want to go higher Matt, good pice of info. You got to wonder if they can get away then would E85 or direction injection be more likly to be able to go higher compression.
Tony
