Old 01-22-2008, 06:26 PM
370cc injectors?
Hi.
does anyone here have any 370cc Nissan fuel injectors that they want to sell?
I actually only need one more
but I am open to suggestions.
I could also use the Nissan fuel injector plugs/clips.
I found out today that the plugs/clips from a 1996 Nissan Sentra GXE 4 cyl will also fit.
Thanks,
Old 01-22-2008, 07:05 PM
http://cgi.ebay.com/ebaymotors/6-Nis...QQcmdZViewItem
There your connectors. Don't need all 6? I'll take two. (Maybe.)
How positive are you the Sentra ones will fit?
Old 01-22-2008, 07:20 PM
sicksubie's Avatar
I got your voicemail btw, but dont have anything to help...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-22-2008, 08:41 PM
[QUOTE=NikFu S.;522928
How positive are you the Sentra ones will fit?[/QUOTE]
I was at a wrecking yard today, and the stock appearing wiring connectors fit the injectors that I brought with me.
Old 01-22-2008, 08:48 PM
Do you have a picture of them? I should be able to find some in the yards???
Old 01-22-2008, 10:00 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I sense that Tom's up to something big
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-22-2008, 10:46 PM
Speedklix's Avatar
Locker Link Solution
I believe I have two reconditioned 370s left... I'll have to check.
make me an offer. I'm working in the shop tomorrow night, so I'll bring em home and let you know.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 01-23-2008, 05:42 AM
GREAT!
Sending PM.
Old 01-23-2008, 05:55 AM
Dave,
what is your E-Mail address so I can send you pictures of the injectors.
Old 01-23-2008, 05:57 AM
I got LANs Stage 2V7 chip!
he he he he he he he he he he he he he he he he he he he he he he he he he
Old 01-23-2008, 06:34 AM
Tim's Avatar
Tim Tim is offline
Wow... I thought you were running it this whole time. I can't wait to see your next gtech run then
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-23-2008, 06:45 AM
Yea!
The stock injectors kept up with boost untill about 8 or so PSI!
But now with the 6 rib belt, and a better SC bracket it goes lean REAL FAST!!!
Readings coming!!!
86 Days!
Old 01-23-2008, 07:00 AM
Tim's Avatar
Tim Tim is offline
Yea!
Readings coming!!!
86 Days!
Sweet... I hope to get to Reading this year so I'll get to see it
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-23-2008, 07:51 AM
Sweet... I hope to get to Reading this year so I'll get to DRIVE it
Fixed it!
Old 01-23-2008, 07:57 AM
Yea!
Readings coming!!!
86 Days!
That looks good Tom, keep up the good work.
My own Eaton driven [M112] system in England works very well with the current pulley giving around 6 lbs boost.
I hope you don't mind me giving a small note of caution, as I'm fully aware you have a lot more engineering expertise and experience than I have.
My figures which are a guesstimation would put you making around 280 hp with 7 to 8 pounds, but at this boost your in-cylinder temperatures are close to 1200 degress F, getting to be too high. [Ideally they need to be about 1075 for safety]
Don't get me wrong here, I know your blower is belt drive, and the heat I am talking about is not heat leaked over from the usual exhaust drive layout as in a turbo. The heat I mention is caused by compression, directly related to boost poundage.
So my note of caution is about going beyond 8 lbs without a charge cooler or without water injection to keep cylinder temps safe.
I'm putting in water myself because my next pulley will be 10 lbs. Like yourself, I will be upgrading injectors also.
Best of luck with it Tom.
