Old 12-14-2007, 03:14 AM
subbieatnz's Avatar
minor svx engine power ups?
hey im just wondering what i can do 2 get an bit more power from my svx?
i just want to do miner stuff till i can save up enought money for getting an lot more power out of it
thanx
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 12-14-2007, 03:18 AM
subbieatnz's Avatar
I Know about doing air filter and exhaust to make it breath better
just what else can i do?
1983 RX Silver Grey
Old 12-14-2007, 07:18 AM
processengr's Avatar
ECUtune chip for about $240+installation, 4.44 gears for $1200ish installed.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 12-14-2007, 09:42 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
In terms of simple to harder:
1. remove the intake "saxaphone" within the wheelwell
2. ECUTune 1v5 chip
3. 2 in one out high flow primary cat with 2.5 pipe back to a 2.5" resonator and then to the stock muffler
4. TomMyplx intake pipe from MAF to TB
5. Underdrive crank pulley
6. 5 spd MT or 4.44 AT swap with associated rear diff
7. ECUTune 2v7 chip with Z32 MAF and 370cc injectors
8. OT or YT custom headers
9. Cams (LAN's or mine...whenever I actually get around to actually testing mine out)
9. Turbo/S/C...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-14-2007, 09:44 AM
SubaSteevo's Avatar
No longer blue member
Throttle body coolant bypass. $3 and 15 minutes of your time.
-Steve
01' MSM Lexus IS300
Old 12-14-2007, 10:23 AM
Mr. Pockets's Avatar
Moderator
Moved to correct forum. Please post in the appropriate forum in the future. Thanks.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-14-2007, 09:02 PM
subbieatnz's Avatar
whats that? whats it look like and where do ya get 1 from?
1983 RX Silver Grey
Old 12-14-2007, 09:14 PM
It's Just Eric's Avatar
Missing in action
basicly, there's a coolant line that runs through your throttle bodies. Some people have simply disconnected them from the throttle body and coupled the lines together with a fiting. Basicly, the theroy is, the hot coolant running through the throttle increases the air temperture, so bypassing that results in more power.To be honest, I dont think it's THAT much of a benefit, plus, im pretty sure they put the coolant lines there for a good reason
for an ENGINE power increase, you're really not gotig to get any benifits from something cheap, but, the overall feel f the car can be improved very inexpensivly. Start off small....Remove the intake resonator, install a lightweight pully, mabey install some phenolic spacers...Then invest in some polyurethane bushings for the swaybars, get some endlink bushings and rear subframe spacers from SVXFiles, upgrade to slotted rotors and stainless lines...then save up money for an exhaust, intake (and not some chintsy cone filter...do your reesearch) then save up for a 5mt, then do some engine manegment and cams.somewhere during this process, you might invest in a fiberglass hood, and remove some unessenial bulk. By this point, your car should be quite fast, but, if you want to go faster, you're going to essentially need a built engine and forced induction.
R.I.P Cool Signature.
Old 12-14-2007, 09:33 PM
My guess for the throttle body coolant is that the system is there to prevent ice build up in the throttle body. When air moves through a venturi (a tube with flared ends) it accelerates. As it accelrates pressure and temperature drop. This temperature drop can be very significant when the air is moving very fast, enough that in high humidity conditions the moisture in the air can freeze and build very quickly inside the throttle body and on the throttle plates, causing restrictions to the engine drawing air in. By warming the throttle body you prevent the formation of ice.
This is very similar to the carburator heat system small airplanes use to prevent icing in the carburator.
Old 12-14-2007, 09:45 PM
Bill:
You are saying a 5mt swap is easier than a 2v7? If so, I think I have a very rough road ahead.
Old 12-14-2007, 10:19 PM
94SubieSVX's Avatar
OOC for a while
Bill:
Maybe cheaper.
bLAh
Old 12-14-2007, 11:04 PM
What's cheaper than what? Stage 2 is costing me just under 800, and 5MT is costing me over 2k.
Old 12-14-2007, 11:23 PM
94SubieSVX's Avatar
OOC for a while
Wait...wasn't thinking when I posted that lol.
bLAh
Old 12-15-2007, 03:36 AM
subbieatnz's Avatar
phenolic spacers
whats are those?
1983 RX Silver Grey
Old 12-15-2007, 03:42 AM
They are spacers that are phenolic, duh.
phe·no·lic (f-nlk, -nlk)
adj. Of, relating to, containing, or derived from phenol.
n.
Any of various synthetic thermosetting resins, obtained by the reaction of phenols with simple aldehydes and used as adhesives.
space /speɪs/ [speys] noun, verb, spaced, spac·ing, adjective
–noun 1. the unlimited or incalculably great three-dimensional realm or expanse in which all material objects are located and all events occur.
Just kidding.
http://www.outlawengineering.com/index.html
Click.
