A little something I've been working on.....
These are in no particular order but you should get the jist of what's goin' on.
bLAh
bLAh
Cooooooooooool! Did you intend to go through the front of the spoiler though?
Yes I did.
When I started it, I got a little anxious/impatient and didn't move the wing back. That would have made it easier to make the transition to the rear window plastic pieces(I forget what they're called). But what I did was just get a general line looking from the side, then used styrofoam to help shape it out. Then put bondo on it and shaped it out using the bondo. What I haven't got to start yet was, I'm gonna re-locate the third brake light to inside the wing like the prototype. I'll find the pic I saw it in then post it. I'm also gonna try to make the wing have the same curve as the trunk itself. (Looking down from above the trunk, I want the wing to take that curve). Also once all of the shaping, sanding, etc. is finished, I might put a layer of fiberglass over to strengthen it up a bit. I'm excited I can finally work on this more, but it's only cuz my diff decided to blow up the other day
bLAh
Looks nice, sanding that inside curve is going to be a B!tch!
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
Tell me about it... I tried to a little bit, but when it's all choppy and rough like in the early pics, its hard to get a good sanding rhythm going. That's when I would whip out the grinder, but it won't fit in that tight area.
bLAh
I've actually had the idea of doing this bouncing around my head for a while. I think I would probably not bother using the stock wing at all and make one out of foam, then glass over it.
